PCV Valve on Race Car ??
#2865280
12/27/20 02:39 PM
12/27/20 02:39 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey Guy's I wanted to pick your brains a little . I have used the evack systems on my car for years but recently one of the one way valves broke and it made my engine puke a lot of oil everywhere. I found the problem but went back to a standard PVC setup because it is still a street car. What is the down side to using the PCV at the track ?? Just wondering because it works great on the street even when I jump into it a little. Advice or opinions welcome.
6.50 @105.26
Re: PCV Valve on Race Car ??
[Re: AndyF]
#2865321
12/27/20 04:23 PM
12/27/20 04:23 PM
Kindafast
Seaford, Va
Thanks guys , I was wondering about the vacuum at WOT myself. I have played with it a little on the street but not at WOT so that is a concern . Wonder if I put one evac tube on one side when the exhaust is open and leave the PCV on the other side ?? Like I say I am just fishing right now for the best of both worlds.
6.50 @105.26
[Re: rickraw]
#2865322
12/27/20 04:25 PM
12/27/20 04:25 PM
Kindafast
Seaford, Va
You would be contaminating the intake charge which could cause detonation, plus creating deposits on the valves & pistons. 2cts. Wonder how much it would do that with Very limited street driving ??
6.50 @105.26
[Re: justinp61]
#2865329
12/27/20 04:44 PM
12/27/20 04:44 PM
Kindafast
Seaford, Va
I've always ran a pcv valve on my street/strip engines and never had any issues with any build up. When we dynoed my 434 the pcv valve was worth 4 hp. I like the sounds of that, Thanks. Extra HP and ease of use too. Nice !! No problems at WOT ??
6.50 @105.26
[Re: rickraw]
#2865336
12/27/20 04:57 PM
12/27/20 04:57 PM
Kindafast
Seaford, Va
Get an air -oil separator, problem solved. Okay got my curiosity up . Are you talking about like the ones on air lines from a air compressor ?
6.50 @105.26
[Re: Kindafast]
#2865339
12/27/20 05:01 PM
12/27/20 05:01 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I've always ran a pcv valve on my street/strip engines and never had any issues with any build up. When we dynoed my 434 the pcv valve was worth 4 hp. I like the sounds of that, Thanks. Extra HP and ease of use too. Nice !! No problems at WOT ?? No problems anywhere.
[Re: justinp61]
#2865354
12/27/20 05:34 PM
12/27/20 05:34 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
Here's an adjustable pcv valve. I'd like to try one. My street car has a breather tank on each side of the radiator with 12an lines going to each valve cover. http://mewagner.com/?p=444
[Re: ProSport]
#2865362
12/27/20 05:47 PM
12/27/20 05:47 PM
Kindafast
Seaford, Va
Here's an adjustable pcv valve. I'd like to try one. My street car has a breather tank on each side of the radiator with 12an lines going to each valve cover. http://mewagner.com/?p=444 That thing is pretty interesting indeed. Pricey but nice. So you have catch cans on both sides of the engine ?? Filters on the catch cans so they can breathe ??
6.50 @105.26
[Re: Cab_Burge]
#2865369
12/27/20 05:59 PM
12/27/20 05:59 PM
Kindafast
Seaford, Va
Thanks Cab , I appreciate everyone's input. I think I will try to run it next year with a PCV and if it pukes a little take my evac system with me just in case..
6.50 @105.26
[Re: rickraw]
#2865712
12/28/20 02:38 PM
12/28/20 02:38 PM
Posts: 19,591 north of coder
moparx
i have a couple of those i got for my toys a few years ago when there was a group buy here. unfortunately, i haven't got either of my toys put together enough to try them out. i truly believe these things will do the job intended, plus they are rebuildable. as to the separator, how about one of those recommended for the new challengers and chargers ?
[Re: Erick Char]
#2865755
12/28/20 03:54 PM
12/28/20 03:54 PM
Kindafast
Seaford, Va
Thanks for all the info on that Wagner PCV. I will give that a shot . Nice looking setup you have by the way..
6.50 @105.26
