Lubricating oil for sonic testers #2864937
12/26/20 02:49 PM
12/26/20 02:49 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I got my new ultrasonic tester out today to check it out and it says to use a drop of "lubricating oil" on the probe, but it didn't come with any. Looking on the interweb, a type of glycerin seems to be the most used product, but on cast iron, vegetable oil could be a substitute? What do you use?
Thanks, Brian
Re: Lubricating oil for sonic testers [Re: '72CudaRacer] #2864940
12/26/20 02:56 PM
12/26/20 02:56 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I use grease to make the soundwaves come through the curved cylinders onto the flat probe. I also do not use the recommended iron calibration value, but use the one giving best corresponding measurement on top of a cylinder near a waterhole that you can auctally measure with a dial caliper.
Re: Lubricating oil for sonic testers [Re: '72CudaRacer] #2864942
12/26/20 02:58 PM
12/26/20 02:58 PM
Mine came with a small bottle of testing solution, I think it is the same stuff use for medical sonic testing scope
I have use white lubriplate type grease and got the same numbers so maybe you can to twocents
Find a smooth thin machine area on a head or block and measure it with a micrometer or even a set of dial calipers and then measure it with your sonic tester and see how much difference you get scope If it is a small amount, less than .0030 I would use it and go from there twocents
Can you calibrate your tester to a known thickness by adjusting the frequency ? If so maybe you can do that also scope work
Re: Lubricating oil for sonic testers [Re: '72CudaRacer] #2864945
12/26/20 03:07 PM
12/26/20 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
My tester came with a small quantity of silicone grease, when it ran out I use silicone dielectric grease (Dow DC4); no difference when comparing the two.
Re: Lubricating oil for sonic testers [Re: John_Kunkel] #2864973
12/26/20 04:33 PM
12/26/20 04:33 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Lubriplate engine assembly grease works well for me. I also like using a mic or caliper to verify the read out.
Re: Lubricating oil for sonic testers [Re: DavidDean] #2865027
12/26/20 07:41 PM
12/26/20 07:41 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Dielectric grease worked for me also, also did the test on a couple of measurable spots on the block. The ears where the motor mounts bolt up work good for me.
Re: Lubricating oil for sonic testers [Re: '72CudaRacer] #2865029
12/26/20 07:42 PM
12/26/20 07:42 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Just got mine couple days ago. Was wondering the same thing as i dont know what glycerin is.
Re: Lubricating oil for sonic testers [Re: mopar dave] #2865035
12/26/20 08:01 PM
12/26/20 08:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I bought a case of 4oz bottles years ago from Grainger when it was much much cheaper. It will last several lifetimes. Lol. Amazon has several list too.
https://www.grainger.com/mobile/product/REED-INSTRUMENTS-Ultrasonic-Couplant-Gel-161D96
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Lubricating oil for sonic testers [Re: pittsburghracer] #2865079
12/26/20 09:45 PM
12/26/20 09:45 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You need to seek out the kindest nurse you know and ask for some ultrasound gel. The stuff they smear on momma's belly. Nothing finer.
If you are single make it a dual purpose mission. : D
Re: Lubricating oil for sonic testers [Re: Jeremiah] #2865165
12/27/20 10:14 AM
12/27/20 10:14 AM
Mt Morris Michigan
Mt Morris Michigan
hahaha, yeah. Can you use baby oil? I think you can get the ultrasound gel at rite-aid.
Re: Lubricating oil for sonic testers [Re: mopar dave] #2865206
12/27/20 11:59 AM
12/27/20 11:59 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Vasaline it works for anything whistling
Re: Lubricating oil for sonic testers [Re: B G Racing] #2865225
12/27/20 12:48 PM
12/27/20 12:48 PM
Mt Morris Michigan
Mt Morris Michigan
ok, yeah, great! Ill try that.
Re: Lubricating oil for sonic testers [Re: mopar dave] #2865627
12/28/20 11:11 AM
12/28/20 11:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Another vote for vasoline, cheap easy to find and works great
Re: Lubricating oil for sonic testers [Re: Al_Alguire] #2865732
12/28/20 03:04 PM
12/28/20 03:04 PM
Texas
Chief Offline
Chief  Offline
Texas
Lithium grease works well. Hell, I've even used spit in an emergency.. No Joke..
Dave Covey
Re: Lubricating oil for sonic testers [Re: Chief] #2869244
01/05/21 11:06 AM
01/05/21 11:06 AM
an8sec70cuda Offline
I was recently playing around w/ a sonic tester a friend of mine loaned me. It came w/ a bottle of special oil and I compared the readings from the supplied oil to regular white lithium grease I've been told to use in the past. They read exactly the same. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Lubricating oil for sonic testers [Re: an8sec70cuda] #2869251
01/05/21 11:34 AM
01/05/21 11:34 AM
Mt Morris Michigan
Mt Morris Michigan
I tried the cooking oil and it works great as well.
