360 based Stroker Crank Kit and Balance #2864856
12/26/20 11:26 AM
12/26/20 11:26 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I’m using mid 70’s 360 block. I will be getting steel crank, H beam rods, forged pistons and aiming for 11:1 compression - using 727 trans
Am I correct in assuming the “balance” now is relative to the new parts and not the block? I haven’t decided where I’m getting the kit but what I need to know is what balancer and flex plate I need to look for. Also, I will be using a crank trigger.
Re: 360 based Stroker Crank Kit and Balance [Re: lostdog] #2864866
12/26/20 12:20 PM
12/26/20 12:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Are you going to keep it externally balanced?
Boffin Emeritus
Re: 360 based Stroker Crank Kit and Balance [Re: lostdog] #2864870
12/26/20 12:32 PM
12/26/20 12:32 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
yes the new combo will be balanced to your parts selection...would be your choice internal or external.
i purchased a mopar cast crank/eagle rod/diamond piston combo and went internal...the cast crank needed a few chunks of mallory to balance.
Re: 360 based Stroker Crank Kit and Balance [Re: lostdog] #2864876
12/26/20 12:44 PM
12/26/20 12:44 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I would buy the kit and have my machine shop do the balance work, then run whatever neutral balance damper and flex plate you wish. I have a Innovators West damper on my 434, they have an option to have the magnets for a crank trigger built in. I've kicked myself in the butt for not having it done to mine.
Re: 360 based Stroker Crank Kit and Balance [Re: maxwedge1] #2864877
12/26/20 12:47 PM
12/26/20 12:47 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am doing a 4" crankshaft 360 deal right now..................Molnar crank and rods , Weisco pistons , had it internally balanced and it was a piece of cake.
Took weight out , no Mallory required.
Neutral balance ATI damper and MoPar performance flex plate.
I did not do it on this deal , but my last , I had the damper built with the G.M. / Chevrolet pattern on the front which opens up your options for crank trigger and pulley / drive mandrel selection.
The number of choices this opens up is VAST , and significantly cheaper.
Re: 360 based Stroker Crank Kit and Balance [Re: lostdog] #2864946
12/26/20 03:10 PM
12/26/20 03:10 PM
The block is a piece of a cast iron that does not rotate so it has nothing to do with the rotating parts inside of it work
My message is you now have the ability to have your new parts balanced either externally or internally, the differences are in the harmonic balancer and torque converters you have to use, if you want to be able to swap converters later it is easier and safer to use a internally balance converter now instead of having to have another custom externally balanced converter made to fit your motor later work
You can use a standard neutral balanced harmonic balancer with a aftermarket externally balanced flexplate to use with internal balanced converters also , you have several different choices to be made now scope
Re: 360 based Stroker Crank Kit and Balance [Re: Cab_Burge] #2865031
12/26/20 07:49 PM
12/26/20 07:49 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Yes, this is the information I need . Thanks, guys!
Re: 360 based Stroker Crank Kit and Balance [Re: lostdog] #2865095
12/26/20 10:37 PM
12/26/20 10:37 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The eagle 4" steel, h-beam, Mahle piston combos are internal balanced, no Mallory, weight is removed from the crank. If you do not want a kit I would go eagle crank, small block chevy rods, Mahle piston so your block notching will be near zero.
