Electronic ignition question #2864750
12/25/20 08:07 PM
12/25/20 08:07 PM
KS
68SportSatvert Offline OP
KS
I have a complete MOPAR electronic ignition system for my 68 383 HP in my 68 Sport Satellite convertible. I also have a MSD 6AL. Which one is better or does it really matter? Thanks in advance.
Re: Electronic ignition question [Re: 68SportSatvert] #2864751
12/25/20 08:17 PM
12/25/20 08:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You are likely to get differing opinions but I like the factory stuff, especially when it comes to diagnosing (if needed) and availability /cost of parts. get stuck somewhere on a roadie with that MSD and your up schitt creek without a paddle twocents beer
Re: Electronic ignition question [Re: TJP] #2864753
12/25/20 08:27 PM
12/25/20 08:27 PM
PA
70Duster Offline
70Duster  Offline
PA
Agreed. In this case stay with the factory MOPAR setup.
Re: Electronic ignition question [Re: TJP] #2864759
12/25/20 08:54 PM
12/25/20 08:54 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
LOL, 6AL's are everywhere in every town. Much more likely to turn one up than you are a Mopar style ECU at a parts store anymore. When you do find one it's an overseas unit that probably won't work very long if at all. Things aren't the same as they were 10 years ago.
The things that make the MSD head and shoulders above the Mopar unit is the additonal features. It comes with a rev limiter that you can tailor to your needs and you can plug in things like two steps and timing controllers. I can adjust my timing from the drivers seat.
'63 Dodge 330
11.19 @ 121 mph
Re: Electronic ignition question [Re: 68SportSatvert] #2864767
12/25/20 09:13 PM
12/25/20 09:13 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
what is wrong with your current system?
if it aint broke ? save your money .
i set up both electronic and points , done wright very minimal diff !
what is your max rpm !
Re: Electronic ignition question [Re: calrobb2000] #2864779
12/25/20 09:53 PM
12/25/20 09:53 PM
KS
KS
I'm putting the engine together for the first time and have a couple of options which is why I'm asking. I also have a Pertronix distributor but it doesn't have a vacuum advance.
Re: Electronic ignition question [Re: 68SportSatvert] #2864825
12/26/20 08:48 AM
12/26/20 08:48 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The last several cars I’ve done for customers, I’ve used the complete FBO system. They seem to start better and run better than the factory ECU. They are of questionable quality. I’ve not used one in years. I’ve got and MSD on my Cuda. It’s went out once but I had an older unit for backup. Some of the new MSD unit are giving trouble. My biggest concern with MSD is breaking down on the road. I think these old cars need a backup ignition in the trunk that you can make a repair on the spot. Who wants to be stranded anymore. The Petronix unit is not easy to change in a pinch. The good about the FBO unit is a stock ECU and a ballast resistor change will get you home if the FBO unit goes out. I have not had one fail yet though.
Re: Electronic ignition question [Re: 68SportSatvert] #2864831
12/26/20 09:55 AM
12/26/20 09:55 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
MSD and the Mopar units are now made in china, so reliability is down the drain. Either points, or Pertronix would be the choice.
Re: Electronic ignition question [Re: 71birdJ68] #2864833
12/26/20 10:07 AM
12/26/20 10:07 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My car would fire up quicker with MSD vs mopar ignition. So I say MSD.
Re: Electronic ignition question [Re: 71birdJ68] #2864842
12/26/20 10:31 AM
12/26/20 10:31 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Unfortunately I think there is no real way out. Why are Chinese electronics substandard, because they use substandard components. Where are you going to find better components? Most of them are made in China too. So a USA manufactured unit using Chinese components probably wouldn't be any better. I wish someone had the internal schematic for the Mopar ECU, someone handy with electronics could probably improve on it AND dig up quality components. Remember, even back in '72 everything in them was low bid!
Re: Electronic ignition question [Re: 68SportSatvert] #2864844
12/26/20 10:50 AM
12/26/20 10:50 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I am going to say go with the GM HEI conversion. The HEI module is more reliable, more powerful, more available and less expensive than any Mopar box. Kind of a win, win, win, win.
Edit:. I see there is another thread where the HEI is slammed so I guess you have to take this suggestion with a grain of salt. Or find some old modules just like you need to do with Mopar ecu's.
Re: Electronic ignition question [Re: 6PakBee] #2864954
12/26/20 03:26 PM
12/26/20 03:26 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I wonder if that's true across the board. Many of us can remember when anything from Japan was junk and now they're known for quality. At some point in time they were shamed into improving their products, China might be doing the same...especially when an American company monitors quality control. shruggy
Re: Electronic ignition question [Re: John_Kunkel] #2864957
12/26/20 03:40 PM
12/26/20 03:40 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Japan had Edwards Deming, all China has is cheap labor and thievery. Vietnam and Malaysia have even cheaper labor. 2¢
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Electronic ignition question [Re: John_Kunkel] #2865059
12/26/20 09:02 PM
12/26/20 09:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up iagree
Re: Electronic ignition question [Re: GY3] #2865060
12/26/20 09:08 PM
12/26/20 09:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
As I stated
Quote
, And I would put 100.00 bet on the availability of a Mopar ECU vs an MSD unit at a parts store in city with a population of less than say 10,000 or even 300,000 twocentswhistling ozbbq
Re: Electronic ignition question [Re: TJP] #2865085
12/26/20 09:59 PM
12/26/20 09:59 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
As I stated
Quote
Keep your money. My hometown is less than 100k. O'reilly has a stock type ECU in stock, Autozone has a 6AL in stock.
Re: Electronic ignition question [Re: John_Kunkel] #2865281
12/27/20 02:39 PM
12/27/20 02:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
John, I wish you were right. My prime example is ignition condensers. Where do you get a quality one today?
Re: Electronic ignition question [Re: 6PakBee] #2865449
12/27/20 09:06 PM
12/27/20 09:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
maybe Accel or old stock on Ebay ?? And keep in mind a lot of our phones, computers and their components, TV's etc. come from ? yep China
Re: Electronic ignition question [Re: TJP] #2865542
12/28/20 01:01 AM
12/28/20 01:01 AM
middle Tennessee
mopower440 Offline
mopower440  Offline
middle Tennessee
I installed the HEI 4 pin module inside a gutted mopar ECU box. Looks stock and the car fires up much easier than it ever did with the mopar box. I just bought a cheap HEI module from oreillys and it does fine.
Re: Electronic ignition question [Re: mopower440] #2865611
12/28/20 10:26 AM
12/28/20 10:26 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Now that is thinking outside the box! up
