Headlights exploded
#2863952
12/23/20 02:49 PM
12/23/20 02:49 PM
Posts: 1,313 Laveen, Arizona
GTSDart340
Laveen, Arizona
I converted from the sealed beam headlight to the halogen capsule bulbs on my 68 Dart. I drove it to work the other day (5 am) and about halfway there I noticed my headlights weren't on. Neither high or low beam lights worked. I pulled the headlight later that day to find that both bulbs had exploded (they were Hella bulbs, plugged into the stock wiring with a relay conversion). There are two fuses in line, a 20 amp and a 30 amp, neither fuse had blown. I can only think of hitting a fairly hard pothole, maybe the impact killed them? Any ideas on what to check? Also the inside of the housing is foggy now, what's the best way to clean it out? See attached pics. Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: Headlights exploded
[Re: stumpy]
#2864050
12/23/20 07:20 PM
12/23/20 07:20 PM
Posts: 870 Avondale AZ
Prodart440
Avondale AZ
How long ago did you do the conversion?
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: stumpy]
#2864054
12/23/20 07:29 PM
12/23/20 07:29 PM
GTSDart340
Laveen, Arizona
You didn't happen to touch the bulbs with your fingers did you? No, I know better
[Re: Prodart440]
#2864055
12/23/20 07:29 PM
12/23/20 07:29 PM
GTSDart340
Laveen, Arizona
How long ago did you do the conversion? About 5 years ago.
[Re: NITROUSN]
#2864111
12/23/20 09:25 PM
12/23/20 09:25 PM
Posts: 4,570 Michigan
MarkZ
Worthy
Worthy
If you already have an H4 housing you might want to give LED headlights a try. Superbrightled.com carries them.
[Re: NITROUSN]
#2864119
12/23/20 09:48 PM
12/23/20 09:48 PM
GTSDart340
Laveen, Arizona
Possible voltage spike due to overcharge? If that happened wouldn't my fuse go first?
[Re: moparjim79]
#2864121
12/23/20 09:50 PM
12/23/20 09:50 PM
GTSDart340
Laveen, Arizona
This is a common occurrence. Its nothing you did, just the price you pay for retrofitting a better design in an antiquated housing. Halogen bulbs need to be sealed from the atmosphere outside the housing. Usually a dielectric greased seal against the housing and bulb will prevent this, but I've found the higher intensity and whiter light bulbs have a very short life expectancy.
Only use a warm soapy water solution to clean the housings, and clean them submerged in the warm solution. Grab a bendable tube cleaning brush with soft nylon bristles. Works great. I bought Hella housings designed for the h4 bulb. I also live in Phoenix, and the car never sees the little rain we do get. It was a little colder than usual that morning though, maybe there was some condensation. But for both bulbs to go at once?
[Re: MarkZ]
#2864123
12/23/20 09:51 PM
12/23/20 09:51 PM
GTSDart340
Laveen, Arizona
If you already have an H4 housing you might want to give LED headlights a try. Superbrightled.com carries them. I've thought about it, I did convert my Magnum to LED. they are much brighter, but also much more expensive.
[Re: DartGTDan]
#2864259
12/24/20 10:09 AM
12/24/20 10:09 AM
Posts: 6,059 Salem
Grizzly
Moparts Proctologist
Salem
I put 2012 Jeep Wrangler headlamps (using relays) in my '71 Dart GT. It is a bolt in, but you will need to the donor wiring connector shell. Now that's what I call using your head. Nicely done.
Mo' Farts
Moderated by "tbagger".
[Re: GTSDart340]
#2864299
12/24/20 12:06 PM
12/24/20 12:06 PM
Posts: 1,443 Central Pa
moparjim79
Central Pa
Only use a warm soapy water solution to clean the housings, and clean them submerged in the warm solution. Grab a bendable tube cleaning brush with soft nylon bristles. Works great. I bought Hella housings designed for the h4 bulb. I also live in Phoenix, and the car never sees the little rain we do get. It was a little colder than usual that morning though, maybe there was some condensation. But for both bulbs to go at once? Thats the same question I posed to myself when I put a set of super bites in my neon. I was less than an 1/8 mile from work and selected my hi beams, they momentarily lit and both went out. I switched back to my low beams and pulled into my spot and then the low beams failed. The same thing has happened to my wife's pontiac at least 3 times.
