Re: old Mopar Performance crate motor question?
[Re: crlush]
#2863553
12/22/20 08:21 PM
12/22/20 08:21 PM
Posts: 15,855 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I owned two of the 300hp versions, and they definitely had dual plane M! manifolds. Btw, both were STRONG engines, and I believe underrated as far as hp and torque. You're correct also in that the 380hp had the single plane. Wish they could still manufacture them. Tire shredding torque.
Facts are stubborn things.
[Re: larrymopar360]
#2863673
12/23/20 12:02 AM
12/23/20 12:02 AM
RWG75
RWG75
I’ve got a 95ish MP 300 hp 360 LA in one of my chargers. Dual plane and I think magnum crates didn’t show up until later. Also have the MP catalog I ordered it from. Dunno if factory or installer but there’s a boilerplate bolted to the backside of the drivers head. Has PN, build date, etc. Can dig more later.
[Re: ]
#2863781
12/23/20 09:07 AM
12/23/20 09:07 AM
RWG75
RWG75
[Re: TC@HP2]
#2864991
12/26/20 05:41 PM
12/26/20 05:41 PM
Posts: 43,540 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I bought a 360/380 short block in the mid 90's and put "X" heads on it then it went in my 68 Dart convertible. That was a strong engine even after I put factory intake, carb, and exhaust manifolds on it...LOL
JB Rhinehart, Realist
A-Body's RULE!
[Re: TC@HP2]
#2864996
12/26/20 05:49 PM
12/26/20 05:49 PM
Posts: 1,404 Central Pa
moparjim79
Central Pa
Came across a 2002 MP catalog in the garage today. It was probably the pinnacle of crate motors at this time. In just the small block range they had 300, 380. 395 and 402 horsepower versions for carbs along with a couple different MPI versions in complete long blocks and every version had a corresponding short block offering as well. Going to disagree with this statement here. Only a few years later they were offering still a wider selection of crates and more power, but I would say it was ramping up swiftly to the pinnacle. Anyone remember the 420" six pack and 440" magnums?
[Re: moparjim79]
#2865159
12/27/20 09:27 AM
12/27/20 09:27 AM
Posts: 1,322 Michigan
crlush
Came across a 2002 MP catalog in the garage today. It was probably the pinnacle of crate motors at this time. In just the small block range they had 300, 380. 395 and 402 horsepower versions for carbs along with a couple different MPI versions in complete long blocks and every version had a corresponding short block offering as well. Going to disagree with this statement here. Only a few years later they were offering still a wider selection of crates and more power, but I would say it was ramping up swiftly to the pinnacle. Anyone remember the 420" six pack and 440" magnums? I remember the 440 magnum, don't know anyone that bought one, would like to know how it would run in an a-body!
[Re: moparjim79]
#2865161
12/27/20 10:02 AM
12/27/20 10:02 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Came across a 2002 MP catalog in the garage today. It was probably the pinnacle of crate motors at this time. In just the small block range they had 300, 380. 395 and 402 horsepower versions for carbs along with a couple different MPI versions in complete long blocks and every version had a corresponding short block offering as well. Going to disagree with this statement here. Only a few years later they were offering still a wider selection of crates and more power, but I would say it was ramping up swiftly to the pinnacle. Anyone remember the 420" six pack and 440" magnums? It's always okay to disagree, but I would counter that with the statement-Maybe the average small block crate engine customer isn't looking to spend 14 grand. 410 6 pack and 440 were super cool, but sold very poorly in comparison to prior generations due to very high prices/no OE parts in them including the block which drove prices way up. I still have a couple 410 6 pack air cleaner decals in my collection from back then. In my humble opinion the prior couple generations were a little nicer bang for the buck based on customer perspective and happiness with the product vs. what was spent. Around 6 grand for the 380 and later 390hp version right at the end of it's run. I got TONS of calls praising the stroker versions of the 5.9, and the stroker shortblock at the end of the run was one of the best values in the catalog.
Rich H.
Esse Quam Videri
[Re: moparjim79]
#2865192
12/27/20 11:17 AM
12/27/20 11:17 AM
Posts: 16,477 On the run…
BloFish
On the run…
I bought this version and am still running it today.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: TC@HP2]
#2865297
12/27/20 03:36 PM
12/27/20 03:36 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Came across a 2002 MP catalog in the garage today. It was probably the pinnacle of crate motors at this time. In just the small block range they had 300, 380. 395 and 402 horsepower versions for carbs along with a couple different MPI versions in complete long blocks and every version had a corresponding short block offering as well. I paid 3200 for my first Magnum 360/300, all new, complete, oil pan to intake. Those were real bargains, even back then! The assembly on some of them wasn't the best, so you might of had to do some re-gasketing, but they were STRONG, and a lot of engine for that kind of money! They were roller cam setups. Only thing I added was a windage tray and they rocked! Smooth idle so you could have a real sleeper with one if you wanted.
[Re: larrymopar360]
#2865468
12/27/20 09:47 PM
12/27/20 09:47 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Got two of the mopar crate LA 360 short blocks....one is the high compression version with piston .008 out of the deck and the second is a low compression version with the pistons down in the bore....forgot how far....as that engine is in my 73 340 Duster. The blocks are 360 LA roller blocks.
Both came with the MP 509 cam....
The high compression short block is still in the blue container....for about 20 yrs now....lol
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
