Edelbrock Carb Inlet Adapter #2862990
12/21/20 03:30 PM
12/21/20 03:30 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
There is an inlet adapter that allows you to connect an Edelbrock carb to the stock steel fuel lines. I have one on my 383. Looking for another for my 440. Its not the Edelbrock 8090.
Grandma always said I had "hands of gold"!
Re: Edelbrock Carb Inlet Adapter [Re: CHRGR69] #2863033
12/21/20 05:25 PM
12/21/20 05:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Edelbrock Carb Inlet Adapter [Re: John_Kunkel] #2863061
12/21/20 06:42 PM
12/21/20 06:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That's what I used on my AVS2 replacement for a car's original AVS.
The fitting seat differs between the original carb body and the Eddy body, and Edelbrock doesn't carry a hardline adapter for the OEM line.
Re: Edelbrock Carb Inlet Adapter [Re: John_Kunkel] #2863279
12/22/20 10:56 AM
12/22/20 10:56 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Re: Edelbrock Carb Inlet Adapter [Re: topside] #2863414
12/22/20 03:41 PM
12/22/20 03:41 PM
moparx Offline
moparx  Offline
The fitting's seat differs between the original carb and the Eddy, so the original fitting doesn't seal to the carb.
i have used that item several times on several different eddy carbs and never had a leakage problem.
was your gasket defective ?
what did you do to solve your problem ?
beer
Re: Edelbrock Carb Inlet Adapter [Re: moparx] #2863497
12/22/20 06:23 PM
12/22/20 06:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No, it was a depth issue in the carb body.
I edited my comment so it hopefully makes more sense.
The Eddy inlet fitting with hose adapter works on the Carter, though.
Re: Edelbrock Carb Inlet Adapter [Re: topside] #2863897
12/23/20 01:21 PM
12/23/20 01:21 PM
moparx Offline
moparx  Offline
i see now. thank you ! up
beer
