Re: Running a 2 step with 4 speed
[Re: joes68340s]
#2862942
12/21/20 02:05 PM
12/21/20 02:05 PM
Posts: 8,344 fredericksburg,va
cudaman1969
fredericksburg,va
Did it years ago, simple diode but I was using the line loc on both (low rpm) but had two buttons. But why not use the line lock for both actions? What it was made to do right?
[Re: joes68340s]
#2862995
12/21/20 03:38 PM
12/21/20 03:38 PM
Posts: 10,046 MN
JERICOGTX
MN
The only way my 2 step works is if I have the line lock button pushed, and the clutch pedal pushed in. I have a switch on the clutch pedal. Release either one, and it will go to the high side of the rev limiter. Kinda fool proof. Won't go on the 2 step in the burnout box, and won't hit it going down track.
69 GTX
68 Road Runner
[Re: cudaman1969]
#2862997
12/21/20 03:50 PM
12/21/20 03:50 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I've been racing my car for more years than I want to admit. I Use a "T" handle on my "H" pattern Hurst shifter that has the button in it. I engineered a circuit, (the term "engineered", is a definite overstatement), for sure, I use the button on the shifter and a separate toggle switch. With the toggle switch off, the rev limiter is in play, but the two step is not, which enables me to do a burnout without hitting the two step. As I pull to the line and shift into first gear, I flick the switch on and now I have my Two step and rev limiter in play. Some guys use a clutch switch, like my son for instance, but I prefer the button on the handle. I've won a few races and lost allot more, as most of us here. I've had my share of .000 and .001 lights over the years. Once you get acclimated to the procedure, it works pretty well. Just my two cents. To each his own, so to speak.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2863003
12/21/20 04:08 PM
12/21/20 04:08 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I run 2 micro switches in series with one on the side cover that is engaged when the trans is in first gear and the other when the clutch is on the floor. That way the only time the 2 step is activated is during launch conditions. I have seen other guys that run it through the horn button circuit. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: cudaman1969]
#2863051
12/21/20 06:16 PM
12/21/20 06:16 PM
68LAR
South Park, Pa.
What rpm-2 stepping are you launching at? For me, it depends on track conditions. Usually no lower than 4600, no higher than 5200 rpm. Slicks between 12 and 13 psi.anything lower the car bogs, anything higher the car spins. I rely on tire spin and not clutch slippage. Being "frugal" with my money, I'd rather change tires every four plus years rather than a disc and flywheel every year. I guess I'm getting cheep in my old age???? I like about ten feet of spin off the line.
[Re: fourgearsavoy]
#2863084
12/21/20 07:44 PM
12/21/20 07:44 PM
Posts: 4,457 Washington
madscientist
Washington
I run 2 micro switches in series with one on the side cover that is engaged when the trans is in first gear and the other when the clutch is on the floor. That way the only time the 2 step is activated is during launch conditions. I have seen other guys that run it through the horn button circuit. Gus What did you use for micro switches?? Everything I’ve found just looked to bulky to me. TIA
[Re: madscientist]
#2863177
12/21/20 11:47 PM
12/21/20 11:47 PM
fourgearsavoy
Rittman Ohio
The one on the transmission is a limit switch from a rear window motor off a Toyota 4Runner . The one that is mounted on my pedal stop is a limit switch I had removed from a bucket saddle of a Telsta utility body . This is just junk I had in my pack-rat stash of electronic parts so I don't have any part numbers for you. Gus
[Re: joes68340s]
#2863205
12/22/20 03:06 AM
12/22/20 03:06 AM
Posts: 608 TN
1DGEMAN
TN
Wiring diagram and 2 different clutch switches.
Real Men shift for themselves
[Re: fourgearsavoy]
#2863259
12/22/20 10:19 AM
12/22/20 10:19 AM
madscientist
Washington
The one on the transmission is a limit switch from a rear window motor off a Toyota 4Runner . The one that is mounted on my pedal stop is a limit switch I had removed from a bucket saddle of a Telsta utility body . This is just junk I had in my pack-rat stash of electronic parts so I don't have any part numbers for you. Gus Thank you. I always appreciate reclaiming stuff. I should be able to find at least one of those switches pretty easy and maybe that one from the Toyota will work on the transmission and clutch pedal.
