Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860690
12/16/20 12:05 PM
12/16/20 12:05 PM
The Great State of PA
tabletop390 Offline
tabletop390  Offline
https://www.skspeed.com/msd-9254-ig...distributor-wires-coil-chrysler-273-360/ is the kit I got and the cheapest I've found. Only bad part is it doesn't come with a crank trigger kit. It works well for the money, wired right into all my stuff. Really fought back and forth with either the Grid or the programmable 6. If I was going crazy with my motor or messing with a two step a lot, I would have gone with the Grid. For all I need, even with nitrous, the programmable 6 works just fine. The MSD 7 is a good box, but I've had to repair way too many through the years and fight with some crazy cut and spliced in stuff to go with the 7. If you do decide to go with any programmable, make sure it's mounted somewhere you can get to it easily to plug into and a laptop with a serial port to make life easy.
Re: Starting from zero - building small block stroker ignition [Re: tabletop390] #2860706
12/16/20 12:24 PM
12/16/20 12:24 PM
an8sec70cuda Offline
iagree The grid is nice, but for what I plan on doing...the 6530 should be fine for me.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Starting from zero - building small block stroker ignition [Re: an8sec70cuda] #2860733
12/16/20 01:09 PM
12/16/20 01:09 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Originally Posted by an8sec70cuda
Most are spraying one big kit and using a progressive to control it. Less complicated than multiple systems.
That's where I'm leaning - progressive bc i believe it will be easier to control in a grudge race
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860740
12/16/20 01:24 PM
12/16/20 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On your engine I would talk to Brett Miller if you want big power
wave
Re: Starting from zero - building small block stroker ignition [Re: MR_P_BODY] #2860772
12/16/20 02:12 PM
12/16/20 02:12 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Monte Smith told me years ago to use a Holley Ecu. Even with a Carb. and now thats what i have. IF you think about it the Holley ECU you can use coil on plug, and have data logging as well as a great nitrous controller. The possiblities really are endless. You can control anything and with a nitrous car on the street you will want a lot of control. You can program dump valves and have crazy accurate control over timing with no fear of rotor phase etc. ITs the best you can get, and it condenses everthing into one unit. No seperate nitrous controller, data logger and ignition. PLUS you get free software updates from Holley. The new V6 has some awsome features for nitrous contol and the dump valves. Take a look and youll see how in th long run it will be way worth it.
....BAD A$$ STREET CAR.....
Re: Starting from zero - building small block stroker ignition [Re: n20mstr] #2860783
12/16/20 02:21 PM
12/16/20 02:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the Holley for my injection but its the V4... I might have to update to the V6
wave
Re: Starting from zero - building small block stroker ignition [Re: n20mstr] #2860915
12/16/20 05:14 PM
12/16/20 05:14 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Which Holley ECU are you referring to ?
'63 Dodge 330
11.19 @ 121 mph
Re: Starting from zero - building small block stroker ignition [Re: GY3] #2860943
12/16/20 06:20 PM
12/16/20 06:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
For what he is doing I imagine it is a Dominator ECU.
In 2015 I ran my MS3 EFI ECU for my ignition but still ran a carb. Got lots of strange looks and lots of questions about coil on plug with a carb.
68 Barracuda Formula S 340
Re: Starting from zero - building small block stroker ignition [Re: n20mstr] #2861006
12/16/20 08:54 PM
12/16/20 08:54 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I have to admit I need to do some better research abs the reason why I asked before I bought anything. This is some great info!
Re: Starting from zero - building small block stroker ignition [Re: GY3] #2861044
12/16/20 09:57 PM
12/16/20 09:57 PM
N
n20mstr Offline
n20mstr  Offline
N
Yes holley dominator ECU . I have coil on plug . And since you can progress 8’stages , I’m progressing nitrous and fuel independently. This allowed me to get rid of the early leannspike and picked up the 60’
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2861046
12/16/20 10:00 PM
12/16/20 10:00 PM
N
n20mstr Offline
n20mstr  Offline
N
It might seem like a big investment at first , but you don’t need a data logger ( at least 900.00 ) or a good progressive controller (500.00 to 2000.00) so you getting both of those along with a great ignition and the ability to update to fuel inj later
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2861276
12/17/20 12:57 PM
12/17/20 12:57 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I don't have anything so I will need a complete compatible system so I am looking for recommendations on distributor, ignition module, wires etc. Also, I will be using a transbrake
This is a street/grudge race '70 Duster
Thanks !
I can answer all your questions and provide you with whatever you want. The Holley is the best system to use today for the reasons already stated. I remote tune cars every day, literally, (I tune on four different systems), and the Holley usually comes out on top without adding third party products. Check out my website fastmanefi.com and for sure if you're on Facebook, because that's where I post my recent tunes almost every day.
Re: Starting from zero - building small block stroker ignition [Re: Mopar_Rich] #2861431
12/17/20 06:38 PM
12/17/20 06:38 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Thanks !
n20mstr was kind enough to give me some info through messenger and I gotta say the technology being applied to these systems is more involved and intimating than I imagined. I will sure check out your social media !
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2861477
12/17/20 08:28 PM
12/17/20 08:28 PM
N
n20mstr Offline
n20mstr  Offline
N
Thanks !
It’s a lot of technology but it’s user friendly . I can do it anyone can!
Re: Starting from zero - building small block stroker ignition [Re: n20mstr] #2861574
12/18/20 12:07 AM
12/18/20 12:07 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would look into ICE Ignition, they are made in Austalia but bad ass for sure.
https://www.iceignition.com/
Re: Starting from zero - building small block stroker ignition [Re: Biginchmopar] #2861666
12/18/20 11:13 AM
12/18/20 11:13 AM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
If I was building a grudge car this is the one box I would use, It would replace your ignition box, 2/3 step, launch retard, your delay box, your bump box, your boost controller, your nitrous controller (wet or dry) allows you to run duel fuel with a cheap GM sensor. Oh and it’s a killer data recorder, if you need a gauges/dash then a $125 android tablet. I am sure I am forgetting a few things, but one thing for sure it has a steep learning curve. Oh one more thing, it has traction control.
Without Data, you’re just another guy with an opinion.
Re: Starting from zero - building small block stroker ignition [Re: sr4440] #2861678
12/18/20 11:50 AM
12/18/20 11:50 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am a big MS3 fan myself. I have run one of the DIYAutotune kits that required assembly(MS3X) for 5 years now and it has been awesome. I like the look of the Holley stuff and the software seems pretty nice but I have thousands of dollars less into this than I would have spent for a Dominator ECU.
Re: Starting from zero - building small block stroker ignition [Re: sr4440] #2861995
12/18/20 11:45 PM
12/18/20 11:45 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Thank you for this !
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2861996
12/18/20 11:46 PM
12/18/20 11:46 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2863520
12/22/20 07:13 PM
12/22/20 07:13 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just chiming in with everyone else. From scratch carbs, with power adder, I'd do the msd CNP with a grid controller for the brain. No more cap, rotor and phase issues. Jerk as much timing as you please without any concern of lighting the wrong hole. Also selectable ignition energy output from just over normal grid to just over 600 mj. That system will light anything you put on it.
