Re: Starting from zero - building small block stroker ignition
[Re: tabletop390]
#2860706
12/16/20 12:24 PM
12/16/20 12:24 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
https://www.skspeed.com/msd-9254-ig...distributor-wires-coil-chrysler-273-360/ is the kit I got and the cheapest I've found. Only bad part is it doesn't come with a crank trigger kit. It works well for the money, wired right into all my stuff. Really fought back and forth with either the Grid or the programmable 6. If I was going crazy with my motor or messing with a two step a lot, I would have gone with the Grid. For all I need, even with nitrous, the programmable 6 works just fine. The MSD 7 is a good box, but I've had to repair way too many through the years and fight with some crazy cut and spliced in stuff to go with the 7. If you do decide to go with any programmable, make sure it's mounted somewhere you can get to it easily to plug into and a laptop with a serial port to make life easy. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) The grid is nice, but for what I plan on doing...the 6530 should be fine for me.
[Re: an8sec70cuda]
#2860733
12/16/20 01:09 PM
12/16/20 01:09 PM
Posts: 361 mississippi
lostdog
mississippi
Most are spraying one big kit and using a progressive to control it. Less complicated than multiple systems. That's where I'm leaning - progressive bc i believe it will be easier to control in a grudge race
[Re: MR_P_BODY]
#2860772
12/16/20 02:12 PM
12/16/20 02:12 PM
Posts: 4,702 On the parachute mount
n20mstr
Monte Smith told me years ago to use a Holley Ecu. Even with a Carb. and now thats what i have. IF you think about it the Holley ECU you can use coil on plug, and have data logging as well as a great nitrous controller. The possiblities really are endless. You can control anything and with a nitrous car on the street you will want a lot of control. You can program dump valves and have crazy accurate control over timing with no fear of rotor phase etc. ITs the best you can get, and it condenses everthing into one unit. No seperate nitrous controller, data logger and ignition. PLUS you get free software updates from Holley. The new V6 has some awsome features for nitrous contol and the dump valves. Take a look and youll see how in th long run it will be way worth it.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2860915
12/16/20 05:14 PM
12/16/20 05:14 PM
Posts: 4,715 Wichita
GY3
Wichita
Monte Smith told me years ago to use a Holley Ecu. Even with a Carb. and now thats what i have. IF you think about it the Holley ECU you can use coil on plug, and have data logging as well as a great nitrous controller. The possiblities really are endless. You can control anything and with a nitrous car on the street you will want a lot of control. You can program dump valves and have crazy accurate control over timing with no fear of rotor phase etc. ITs the best you can get, and it condenses everthing into one unit. No seperate nitrous controller, data logger and ignition. PLUS you get free software updates from Holley. The new V6 has some awsome features for nitrous contol and the dump valves. Take a look and youll see how in th long run it will be way worth it. Which Holley ECU are you referring to ?
[Re: GY3]
#2860943
12/16/20 06:20 PM
12/16/20 06:20 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
For what he is doing I imagine it is a Dominator ECU.
In 2015 I ran my MS3 EFI ECU for my ignition but still ran a carb. Got lots of strange looks and lots of questions about coil on plug with a carb.
68 Barracuda Formula S 340
[Re: n20mstr]
#2861006
12/16/20 08:54 PM
12/16/20 08:54 PM
lostdog
mississippi
Monte Smith told me years ago to use a Holley Ecu. Even with a Carb. and now thats what i have. IF you think about it the Holley ECU you can use coil on plug, and have data logging as well as a great nitrous controller. The possiblities really are endless. You can control anything and with a nitrous car on the street you will want a lot of control. You can program dump valves and have crazy accurate control over timing with no fear of rotor phase etc. ITs the best you can get, and it condenses everthing into one unit. No seperate nitrous controller, data logger and ignition. PLUS you get free software updates from Holley. The new V6 has some awsome features for nitrous contol and the dump valves. Take a look and youll see how in th long run it will be way worth it. I have to admit I need to do some better research abs the reason why I asked before I bought anything. This is some great info!
[Re: GY3]
#2861044
12/16/20 09:57 PM
12/16/20 09:57 PM
n20mstr
Monte Smith told me years ago to use a Holley Ecu. Even with a Carb. and now thats what i have. IF you think about it the Holley ECU you can use coil on plug, and have data logging as well as a great nitrous controller. The possiblities really are endless. You can control anything and with a nitrous car on the street you will want a lot of control. You can program dump valves and have crazy accurate control over timing with no fear of rotor phase etc. ITs the best you can get, and it condenses everthing into one unit. No seperate nitrous controller, data logger and ignition. PLUS you get free software updates from Holley. The new V6 has some awsome features for nitrous contol and the dump valves. Take a look and youll see how in th long run it will be way worth it. Which Holley ECU are you referring to ? Yes holley dominator ECU . I have coil on plug . And since you can progress 8’stages , I’m progressing nitrous and fuel independently. This allowed me to get rid of the early leannspike and picked up the 60’
[Re: lostdog]
#2861046
12/16/20 10:00 PM
12/16/20 10:00 PM
n20mstr
Monte Smith told me years ago to use a Holley Ecu. Even with a Carb. and now thats what i have. IF you think about it the Holley ECU you can use coil on plug, and have data logging as well as a great nitrous controller. The possiblities really are endless. You can control anything and with a nitrous car on the street you will want a lot of control. You can program dump valves and have crazy accurate control over timing with no fear of rotor phase etc. ITs the best you can get, and it condenses everthing into one unit. No seperate nitrous controller, data logger and ignition. PLUS you get free software updates from Holley. The new V6 has some awsome features for nitrous contol and the dump valves. Take a look and youll see how in th long run it will be way worth it. I have to admit I need to do some better research abs the reason why I asked before I bought anything. This is some great info! It might seem like a big investment at first , but you don’t need a data logger ( at least 900.00 ) or a good progressive controller (500.00 to 2000.00) so you getting both of those along with a great ignition and the ability to update to fuel inj later
[Re: lostdog]
#2861276
12/17/20 12:57 PM
12/17/20 12:57 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I don't have anything so I will need a complete compatible system so I am looking for recommendations on distributor, ignition module, wires etc. Also, I will be using a transbrake
This is a street/grudge race '70 Duster
Thanks ! I can answer all your questions and provide you with whatever you want. The Holley is the best system to use today for the reasons already stated. I remote tune cars every day, literally, (I tune on four different systems), and the Holley usually comes out on top without adding third party products. Check out my website fastmanefi.com and for sure if you're on Facebook, because that's where I post my recent tunes almost every day.
[Re: Mopar_Rich]
#2861431
12/17/20 06:38 PM
12/17/20 06:38 PM
lostdog
mississippi
Thanks ! I can answer all your questions and provide you with whatever you want. The Holley is the best system to use today for the reasons already stated. I remote tune cars every day, literally, (I tune on four different systems), and the Holley usually comes out on top without adding third party products. Check out my website fastmanefi.com and for sure if you're on Facebook, because that's where I post my recent tunes almost every day. n20mstr was kind enough to give me some info through messenger and I gotta say the technology being applied to these systems is more involved and intimating than I imagined. I will sure check out your social media !
[Re: lostdog]
#2861477
12/17/20 08:28 PM
12/17/20 08:28 PM
n20mstr
Thanks ! I can answer all your questions and provide you with whatever you want. The Holley is the best system to use today for the reasons already stated. I remote tune cars every day, literally, (I tune on four different systems), and the Holley usually comes out on top without adding third party products. Check out my website fastmanefi.com and for sure if you're on Facebook, because that's where I post my recent tunes almost every day. n20mstr was kind enough to give me some info through messenger and I gotta say the technology being applied to these systems is more involved and intimating than I imagined. I will sure check out your social media ! It’s a lot of technology but it’s user friendly . I can do it anyone can!
[Re: Biginchmopar]
#2861666
12/18/20 11:13 AM
12/18/20 11:13 AM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
If I was building a grudge car this is the one box I would use, It would replace your ignition box, 2/3 step, launch retard, your delay box, your bump box, your boost controller, your nitrous controller (wet or dry) allows you to run duel fuel with a cheap GM sensor. Oh and it’s a killer data recorder, if you need a gauges/dash then a $125 android tablet. I am sure I am forgetting a few things, but one thing for sure it has a steep learning curve. Oh one more thing, it has traction control.
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2861678
12/18/20 11:50 AM
12/18/20 11:50 AM
Bad340fish
Tulsa OK
If I was building a grudge car this is the one box I would use, It would replace your ignition box, 2/3 step, launch retard, your delay box, your bump box, your boost controller, your nitrous controller (wet or dry) allows you to run duel fuel with a cheap GM sensor. Oh and it’s a killer data recorder, if you need a gauges/dash then a $125 android tablet. I am sure I am forgetting a few things, but one thing for sure it has a steep learning curve. Oh one more thing, it has traction control. I am a big MS3 fan myself. I have run one of the DIYAutotune kits that required assembly(MS3X) for 5 years now and it has been awesome. I like the look of the Holley stuff and the software seems pretty nice but I have thousands of dollars less into this than I would have spent for a Dominator ECU.
[Re: sr4440]
#2861995
12/18/20 11:45 PM
12/18/20 11:45 PM
lostdog
mississippi
If I was building a grudge car this is the one box I would use, It would replace your ignition box, 2/3 step, launch retard, your delay box, your bump box, your boost controller, your nitrous controller (wet or dry) allows you to run duel fuel with a cheap GM sensor. Oh and it’s a killer data recorder, if you need a gauges/dash then a $125 android tablet. I am sure I am forgetting a few things, but one thing for sure it has a steep learning curve. Oh one more thing, it has traction control. Thank you for this !
[Re: Bad340fish]
#2861996
12/18/20 11:46 PM
12/18/20 11:46 PM
lostdog
mississippi
