Hemi-style caps for B/RB #2860313
12/15/20 02:40 PM
12/15/20 02:40 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Re: Hemi-style caps for B/RB [Re: topside] #2860329
12/15/20 03:22 PM
12/15/20 03:22 PM
moparx Offline
moparx  Offline
those look like very nice caps.
however, i have always wondered if the big block had enough wall material in the skirt for cross bolt caps.
how much would the minimum wall thickness have to be after the spot face for the bolts ?
beer
Re: Hemi-style caps for B/RB [Re: moparx] #2860341
12/15/20 03:50 PM
12/15/20 03:50 PM
AndyF Offline
AndyF  Offline
Yeah the 512 low deck in my Duster is done that way. It is a bunch of work and not really worth it in the end.
Re: Hemi-style caps for B/RB [Re: AndyF] #2860449
12/15/20 07:38 PM
12/15/20 07:38 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I question the value of this mod too. Seems to me if you're making the power that needs four-bolt mains its time to step up to an aftermarket block - probably for not a whole lot more money than the machining and mains will cost.
Re: Hemi-style caps for B/RB [Re: topside] #2860469
12/15/20 08:45 PM
12/15/20 08:45 PM
When Mopar designed the B and RB motors there was no intent to make the main webbing thick enough to support 2 bolt crossing through that webbing to help strengthen the bottom end, DON'T do that tsk twocents Drilling through the main webbing is asking for a disaster to happen later when the main webbing fails and you run over the crankshaft shock
I have replace the stock main caps with both Ductile iron and aluminum along with ARP main studs because at that time that was the only option in trying to improve the strength of the stock RB and B blocks, not so any more boogie
I'm buying new better blocks so I can really twist the tail of the Tiger to make the new motors wail like a banshee devil
Save your money on buying them and invest it into a good block twocents up
Re: Hemi-style caps for B/RB [Re: AndyF] #2860611
12/16/20 09:07 AM
12/16/20 09:07 AM
The Great White North
RAMM Offline
RAMM  Offline
The article states that the new design doesn't interfere with the oil pan bolts. When did you do this Andy? J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Hemi-style caps for B/RB [Re: RAMM] #2860732
12/16/20 01:08 PM
12/16/20 01:08 PM
AndyF Offline
AndyF  Offline
Not sure, maybe 20 years ago.
Re: Hemi-style caps for B/RB [Re: AndyF] #2861352
12/17/20 03:37 PM
12/17/20 03:37 PM
Texas
Chief Offline
Chief  Offline
Texas
I have a set of Pro Gram 4 bolt caps for sale in the for sale section. Ad #2828673 about 1/3rd of the way down the page. They were installed on my 400 block, but they could be line bored for a RB. Align boring would need to be done anyway. 200.00 plus shipping.
Pro Gram Main Caps
Dave Covey
Re: Hemi-style caps for B/RB [Re: Chief] #2861623
12/18/20 08:01 AM
12/18/20 08:01 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The Milodon caps go further down the main web than the Program caps do. Really depends on the block wall thickness in the main web area after machine work is done wether it adds strength or not. I personally don't like cutting the main web gusset out.. Whats needed is a true (vertical) 4 bolt main. Creates more clamping force. Side bolts tie the block together but create zero clamping force.
Re: Hemi-style caps for B/RB [Re: topside] #2861656
12/18/20 10:36 AM
12/18/20 10:36 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I installed a similar set of caps on a 440. I taught at a tech school, and the machine shop did the work so cost was not an issue. But after three seasons of running pulled it apart to freshen, and it had cracks between the cam journal and the no. 2 main bearing web. Over the years, I did all the normal stuff, block filling, different main caps, girdles, etc. As many have said, if you are building anything much over 600hp, get an after market block, at least they are making them again.
Re: Hemi-style caps for B/RB [Re: topside] #2861861
12/18/20 05:55 PM
12/18/20 05:55 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Always thought it was a shame that Ma Mopar didn't decide to offer B&RB blocks with the Hemi bottom end in them. Not sure if it would have been a financial success or not, but it would have made it a lot easier for the guys like us today.
Re: Hemi-style caps for B/RB [Re: 67_Satellite] #2861869
12/18/20 06:11 PM
12/18/20 06:11 PM
AndyF Offline
AndyF  Offline
If the Mopar engineers had been thinking they would have cast the bosses in the side for the cross bolts and just left them unmachined on the production blocks. It would not have cost any more money but it would've made the blocks capable of being properly cross bolted down the road. They could sold cross bolted wedge blocks over the counter thru Direct Connection. They just weren't thinking that far ahead.
They did produce some cross bolted wedge blocks for NASCAR so they knew how to do it. They just never convinced the production guys to add the material for the bosses.
Re: Hemi-style caps for B/RB [Re: AndyF] #2861877
12/18/20 06:21 PM
12/18/20 06:21 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The bean counters saved 4 cents a block NOT doing that.
Re: Hemi-style caps for B/RB [Re: AndyF] #2862391
12/20/20 12:37 AM
12/20/20 12:37 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
I have a 426 marine block that has the bosses cast in to the sides like a Hemi block. They are not machined, but the bosses are there.
Floyd Lippencott IV
Re: Hemi-style caps for B/RB [Re: mr_340] #2862393
12/20/20 12:43 AM
12/20/20 12:43 AM
That block casting looks a lot like the later (1965 and later)H.D. truck 413 blocks shock
I built a 1972 413 Truck H.D. block for my 1963 Fury street car, I'm going to pull the oil pan off and take a look inside to see if it has those bosses luck
Re: Hemi-style caps for B/RB [Re: cudaman1969] #2862394
12/20/20 12:45 AM
12/20/20 12:45 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
750,000 440's X 4 cents is $30,000 bucks over about 12 years!! That guy got a raise!!
Re: Hemi-style caps for B/RB [Re: mr_340] #2862398
12/20/20 01:03 AM
12/20/20 01:03 AM
AndyF Offline
AndyF  Offline
I saw a block like that a few years back but I didn't have a camera with me at the time. Is there a casting number on the back of the block by the oil pressure port? What does the ID pad say? I don't remember what the ID pad said on the block I saw but I remember that it was a 426 wedge block. The guy who owned it said it came out of a NASCAR shop.
Re: Hemi-style caps for B/RB [Re: AndyF] #2862410
12/20/20 01:53 AM
12/20/20 01:53 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
No casting number on the block that I could find, but it looks like the industrial block. I apparently didn't take a photo of the pad, but as I recall it had 426 MAR on it. I don't know if these were the ones they used in NASCAR or not. I seem to remember reading that the Petty's used the Hemi block and drilled and tapped the top row of head bolt holes. Chrysler probably dropped off truck loads of parts to them back in the 1960s and 1970s.
Floyd Lippencott IV
Re: Hemi-style caps for B/RB [Re: mr_340] #2862469
12/20/20 10:15 AM
12/20/20 10:15 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My personal opinion is that anything that helps tie the bottom end together will be beneficial. When the piston fires it’s not a straight down push but at a 45 degree angle to the main cap-bottom of the block where the side bolt would be.
Re: Hemi-style caps for B/RB [Re: mr_340] #2862691
12/20/20 08:18 PM
12/20/20 08:18 PM
This. Wouldn't it have been nice to go to the boneyard and pick a 400" "B" block from a 77 Newport and throw on a crossbolt upgrade kit and have a 1300-1500 H.P, tolerant package?What could have been....
