Re: Hemi-style caps for B/RB
[Re: topside]
#2860329
12/15/20 03:22 PM
12/15/20 03:22 PM
Posts: 19,599 north of coder
moparx
those look like very nice caps. however, i have always wondered if the big block had enough wall material in the skirt for cross bolt caps. how much would the minimum wall thickness have to be after the spot face for the bolts ?
[Re: AndyF]
#2860611
12/16/20 09:07 AM
12/16/20 09:07 AM
Posts: 1,051 The Great White North
RAMM
Yeah the 512 low deck in my Duster is done that way. It is a bunch of work and not really worth it in the end. The article states that the new design doesn't interfere with the oil pan bolts. When did you do this Andy? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: RAMM]
#2860732
12/16/20 01:08 PM
12/16/20 01:08 PM
Posts: 31,074 Oregon
AndyF
Yeah the 512 low deck in my Duster is done that way. It is a bunch of work and not really worth it in the end. The article states that the new design doesn't interfere with the oil pan bolts. When did you do this Andy? J.Rob Not sure, maybe 20 years ago.
[Re: AndyF]
#2861352
12/17/20 03:37 PM
12/17/20 03:37 PM
Posts: 201 Texas
Chief
Texas
I have a set of Pro Gram 4 bolt caps for sale in the for sale section. Ad #2828673 about 1/3rd of the way down the page. They were installed on my 400 block, but they could be line bored for a RB. Align boring would need to be done anyway. 200.00 plus shipping. Pro Gram Main Caps Dave
Dave Covey
[Re: topside]
#2861656
12/18/20 10:36 AM
12/18/20 10:36 AM
Posts: 883 Missouri
jwb123
Missouri
I installed a similar set of caps on a 440. I taught at a tech school, and the machine shop did the work so cost was not an issue. But after three seasons of running pulled it apart to freshen, and it had cracks between the cam journal and the no. 2 main bearing web. Over the years, I did all the normal stuff, block filling, different main caps, girdles, etc. As many have said, if you are building anything much over 600hp, get an after market block, at least they are making them again.
[Re: 67_Satellite]
#2861869
12/18/20 06:11 PM
12/18/20 06:11 PM
AndyF
If the Mopar engineers had been thinking they would have cast the bosses in the side for the cross bolts and just left them unmachined on the production blocks. It would not have cost any more money but it would've made the blocks capable of being properly cross bolted down the road. They could sold cross bolted wedge blocks over the counter thru Direct Connection. They just weren't thinking that far ahead.
They did produce some cross bolted wedge blocks for NASCAR so they knew how to do it. They just never convinced the production guys to add the material for the bosses.
[Re: AndyF]
#2862391
12/20/20 12:37 AM
12/20/20 12:37 AM
Posts: 3,505 DFW
mr_340
DFW
They did produce some cross bolted wedge blocks for NASCAR so they knew how to do it. They just never convinced the production guys to add the material for the bosses. I have a 426 marine block that has the bosses cast in to the sides like a Hemi block. They are not machined, but the bosses are there.
Floyd Lippencott IV
[Re: cudaman1969]
#2862394
12/20/20 12:45 AM
12/20/20 12:45 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
The bean counters saved 4 cents a block NOT doing that. 750,000 440's X 4 cents is $30,000 bucks over about 12 years!! That guy got a raise!!
[Re: mr_340]
#2862398
12/20/20 01:03 AM
12/20/20 01:03 AM
AndyF
They did produce some cross bolted wedge blocks for NASCAR so they knew how to do it. They just never convinced the production guys to add the material for the bosses. I have a 426 marine block that has the bosses cast in to the sides like a Hemi block. They are not machined, but the bosses are there. I saw a block like that a few years back but I didn't have a camera with me at the time. Is there a casting number on the back of the block by the oil pressure port? What does the ID pad say? I don't remember what the ID pad said on the block I saw but I remember that it was a 426 wedge block. The guy who owned it said it came out of a NASCAR shop.
[Re: AndyF]
#2862410
12/20/20 01:53 AM
12/20/20 01:53 AM
Posts: 3,505 DFW
mr_340
DFW
No casting number on the block that I could find, but it looks like the industrial block. I apparently didn't take a photo of the pad, but as I recall it had 426 MAR on it. I don't know if these were the ones they used in NASCAR or not. I seem to remember reading that the Petty's used the Hemi block and drilled and tapped the top row of head bolt holes. Chrysler probably dropped off truck loads of parts to them back in the 1960s and 1970s.
Floyd Lippencott IV
[Re: mr_340]
#2862691
12/20/20 08:18 PM
12/20/20 08:18 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
They did produce some cross bolted wedge blocks for NASCAR so they knew how to do it. They just never convinced the production guys to add the material for the bosses. I have a 426 marine block that has the bosses cast in to the sides like a Hemi block. They are not machined, but the bosses are there. This. Wouldn't it have been nice to go to the boneyard and pick a 400" "B" block from a 77 Newport and throw on a crossbolt upgrade kit and have a 1300-1500 H.P, tolerant package?What could have been....
