Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28590
07/31/06 11:21 PM
07/31/06 11:21 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
you can stop messin with those afb , avs carbs as 71 HP 383 bees came with holleys !
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28591
08/01/06 12:01 AM
08/01/06 12:01 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I custom fabricated the rod. basically, just took the stock rod, added about 1-1/4", re-threaded it & put a bend in it so it would push straight back instead of at an angle. It seems to adjust and work perfectly. The throttle cable bracket is still in need of some work. Its bent for now & works, but needs to be done correctly. When I was in the process of fabricating that rod, I became aware of a cable system. I'm not sure who makes it, but a buddy of mine says its the best option. Have you looked into that set-up? again, were back to the stock look issue though, I suppose.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: calrobb2000] #28592
08/01/06 01:57 AM
08/01/06 01:57 AM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
hi
Mine came with the Carter AVS
All #s matching drivetrain - Was original to the car when i bought it in 1984(Senior in high school) - Engine had never been apart - I spun a rod bearing in 1984 and yanked the whole thing - Finally had it rebuilt after numerous 383s and 440s
Anyways Carter 4BBL
6125s 1971 383 Automatic AVS HP
Still have it with the factory intake up in the attic - Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: calrobb2000] #28593
08/08/08 01:39 AM
08/08/08 01:39 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
hi
My 70 Bee had a 535-45cfm Holley? I ditched it for a 625AFB and a SD intkae. 17.6mpg and lots more kick!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: DaytonaTurbo] #28594
08/08/08 08:10 AM
08/08/08 08:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yeah I decided to sell my RPM and get a street dominator. RPM is way too tall to clear the hood in my satellite without a drop base air cleaner, plus with the SD I can keep my thermoquad.
You have a 440 , he has a 383 . I would think the RPM would fit under the hood with a stock aircleaner on a 383 .
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: JohnRR] #28595
08/08/08 10:04 AM
08/08/08 10:04 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Measure. Take some aluminum foil and crumple it up in to a loose ball about 3" in diameter. Place it on top of the air cleaner. Close the hood. Open hood. Measure crushed aluminum ball. The Edelbrock RPM intake is just shy of 2" taller than the stock intake. So if you have 2" of clearance, you should be good to go, as long as the hood doesn't flex downward hitting the air cleaner.
If it measures right at 2" clearance or slightly less, the drop base element with the stock top should take care of that.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: therocks] #28596
08/08/08 10:16 AM
08/08/08 10:16 AM
Find a used Holley Street Dominator.Proballt the best BB intake ever made and it will fit under the stock hood.Good bottom and top end.Just they only remake them for the RB motor.Rocky
Someone(not me )currently has one for sale in one of the other sections.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: RapidRobert] #28597
08/08/08 01:34 PM
08/08/08 01:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You guys do know this thread is 2 years old, right?
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: DaytonaTurbo] #28598
08/08/08 02:55 PM
08/08/08 02:55 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Better late than never.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: DaytonaTurbo] #28599
08/08/08 07:18 PM
08/08/08 07:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i wasn't the one that dragged it back up .
it makes little sense for something like this to be able to be brought back up by anyone other than the OP .
