A/F Ratio gauge 12V wiring #2859017
12/12/20 04:43 PM
12/12/20 04:43 PM
Texas
CudaBrown Offline OP
Texas
I'm installing a A/F gauge, AEM UEGO 30-0300, on ac71 Barracuda 383. I initially wired the power from the accessory feed (yellow 3 port connector) within the under dash harness. The O2 sensor "heats" when turned on, and pulls current.
I don't want this current draw when the engine isn't running. I'm thinking I need to be on the ignition run circuit (blue wiring) to feed power to the O2 sensor and gauge.
How have others dealt with the keyed 12V wiring source? Should I go through the firewall and power from the alternator side of the ballast? Is there a better source location on the dash side?
Scott
'71 'Cuda 383 (451, shush!) / 727 / Rallye Red
Re: A/F Ratio gauge 12V wiring [Re: CudaBrown] #2859050
12/12/20 06:02 PM
12/12/20 06:02 PM
Andrewh Offline
Andrewh  Offline
I think you will find key on and acc is going to power it the same.
I don't know how you would tap it except to relay it through the start run circuit to prevent it from coming on in acc only mode.
Re: A/F Ratio gauge 12V wiring [Re: Andrewh] #2859132
12/12/20 09:54 PM
12/12/20 09:54 PM
Texas
Texas
OK, Is there a difference in keying to Acc in the counter clockwise direction versus Acc keyed in the clockwise direction? Thanks for the input.
Scott
Re: A/F Ratio gauge 12V wiring [Re: CudaBrown] #2859145
12/12/20 10:22 PM
12/12/20 10:22 PM
Quote
that's what I'd do. tie it into that circuit
