68 B body parking light question
#2857824
12/09/20 09:22 PM
12/09/20 09:22 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Ok, next silly question.
'68 B body - are the parking lights (front) supposed to be illuminated when the headlights are on ? New M & H harnesses all around, all the grounds are good and all other lights function normally. They come on with the switch in the mid position, but go out when you turn the headlights on.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: 68 B body parking light question
[Re: a12rag]
#2857855
12/09/20 10:19 PM
12/09/20 10:19 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Correct my 68 Charger they turn off with the Headlights on
[Re: 5wndwcpe]
#2857859
12/09/20 10:24 PM
12/09/20 10:24 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Not sure if it's the same, but my Dart doesn't have the parking lights on with the headlights. It's a 68.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#2857949
12/10/20 07:41 AM
12/10/20 07:41 AM
5wndwcpe
Southeast PA
Great. I thought that might be the case, but I wanted to be sure. Thanks gents.
[Re: 5wndwcpe]
#2857994
12/10/20 10:17 AM
12/10/20 10:17 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
69 was the first year to the parking lights staying on while headlights are on. This was made just adding a jumper wire to link rear and front parking lights circuits, but switches remain the same
[Re: 5wndwcpe]
#2858052
12/10/20 12:37 PM
12/10/20 12:37 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
'68 B body - are the parking lights (front) supposed to be illuminated when the headlights are on ? New M & H harnesses all around, all the grounds are good and all other lights function normally. They come on with the switch in the mid position, but go out when you turn the headlights on. When I bought my '68 Roadrunner new, the parking lights would go out when the head lights where on. Over the years I have rewired them so they stay on when the head lights are on, just like the '69's.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: moparx]
#2858098
12/10/20 02:03 PM
12/10/20 02:03 PM
Posts: 849 Avondale AZ
Prodart440
Avondale AZ
I like it better with the parking lights off/ headlights on.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
