Re: 572 Hemi Saga
[Re: RAMM]
#2858736
12/11/20 09:09 PM
12/11/20 09:09 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 572 Hemi Saga
[Re: fast68plymouth]
#2858831
12/12/20 01:37 AM
12/12/20 01:37 AM
Posts: 31,034 Oregon
AndyF
Thread derailment!!
In reference to Transmans post about the carb tuning and bsfc. It’s not a good idea........ since its not directly indicative of whether or not the carb is rich or lean.
Bsfc is an efficiency reading...... the result of measured power vs fuel consumed. Nowhere is the ratio of air to fuel referenced to arrive at a bsfc number.
Sure.......”generally” high bsfc numbers track with rich a/f ratios, but they don’t always.
I have tested a number of motors through the years that really didn’t like lean mixtures. You’d richen them up....... a/f ratio reading would confirm....... motor would make a big move in inscreased power....... bsfc would go down.
What high bsfc numbers are really telling you is....... you’re not making good power for the amount of fuel you’re using.
. Just ran a 520 inch BB Ford on the dyno the other day. This is a street motor for a pickup truck. Low compression, small cam type of motor. It made 450 hp and used 300 lbs/hr at WOT. Worst BSFC I've ever seen on the dyno. Engine ran nice and smooth. Sounded great, had a ton of vacuum at idle. Owner will be happy with all the torque but I don't think he will be happy with his gas bill!
Re: 572 Hemi Saga
[Re: AndyF]
#2859327
12/13/20 12:28 PM
12/13/20 12:28 PM
Posts: 1,051 The Great White North
RAMM
Quick video of the air cleaner pull. J.Rob 572 Hemi Air Cleaner Pull
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: 572 Hemi Saga
[Re: RAMM]
#2859394
12/13/20 02:06 PM
12/13/20 02:06 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
Did the motor like or hate those air cleaners? I've seen both results depending on the air cleaners used
Re: 572 Hemi Saga
[Re: Cab_Burge]
#2859572
12/13/20 08:50 PM
12/13/20 08:50 PM
RAMM
Not sure but it was 734HP without and 718HP with the air cleaners. J.Rob
Re: 572 Hemi Saga
[Re: justinp61]
#2859573
12/13/20 08:51 PM
12/13/20 08:51 PM
RAMM
On another thread I read that a single would be worth 30-40HP which seems reasonable. J.Rob
