Re: Harmonic balancer recommendations
[Re: mickm]
#2857798
12/09/20 08:41 PM
12/09/20 08:41 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
When it comes to your decisions on you would you shop around for the cheapest surgeon you could find if you found out you needed brain surgery? Why put the cheapest harmonic balancer you can find on a large cubic inch Hemi that you have a ton of money and time in already Don't buy the cheaper ones Buy the 3 ring ATI and be happy and worry free
[Re: mickm]
#2857799
12/09/20 08:43 PM
12/09/20 08:43 PM
Posts: 11,542 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
540 Hemi and you're willing to hang a Chinese balancer on it? Cause that's what you're going to have.
ATI - buy once, cry once. Even if you have to find a decent used one.
[Re: topside]
#2857852
12/09/20 10:07 PM
12/09/20 10:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've run Fluidampers on a couple of my motors without any problems. Why is the ATI superior to them ? Not arguing, just seeking clarification. I have run both and still do but the Fluidamper weight is a fair more than the ATI.. why spin the added weight when you dont need to
[Re: justinp61]
#2857982
12/10/20 09:46 AM
12/10/20 09:46 AM
Posts: 11,710 Portage,michigan
B3422W5
Portage,michigan
I put a Innovators West on my 434" small block. Not cheap, but neither was the engine. What i am using to. Nice units
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2858001
12/10/20 10:29 AM
12/10/20 10:29 AM
Posts: 4,669 Wichita
GY3
Wichita
I cheaped out and bought the one from 440Source.
Needless to say it came apart at the rubber isolator. No high rpm's, either!
[Re: GY3]
#2858040
12/10/20 12:19 PM
12/10/20 12:19 PM
Posts: 4,673 On the parachute mount
n20mstr
I ran a fluidamper for years, on multiple BB. I only switched to an ATI after i had one valve spring break, and wore a few main bearings a lil wierd. Was it the fluidamper fault ? i really cant say, but the machine shop i use wanted me to switch. We put an ATI on my sons junkyard magnum , only because no one has a "cheap" one for a externally balanced magnum
....BAD A$$ STREET CAR.....
[Re: mickm]
#2858407
12/11/20 10:13 AM
12/11/20 10:13 AM
Posts: 1,755 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
Same recommendation as LA360. I used the small block 64277 damper with the external balance offset weight. No problem with the unit, no slippage.
I will say this though: double-check the process with the shop that'll be doing the balance for you. I explained what I wanted done to the shop I dealt with (1st and ONLY visit), brought them a brand spankin' NEW damper. Job was done, I went back to pick it up only to find that they drilled a number of spots on the damper to balance the assembly out!!
[censored]???
Basically, that's a one-time-use approach since I can't use this damper anywhere else if I want to have the ability to replace a damper should it get damaged!
[Re: mickm]
#2858433
12/11/20 10:55 AM
12/11/20 10:55 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Short answer: I would get an ATI. Long answer: It depends. If you have a ton of belt-driven accessories, the further the damper strays from 440 territory the more effort it will take to set up. It might not be worth the trouble. If you're going to run stock Hemi pulleys, then you need a stock Hemi damper which is dimensionally different from the rest, or you can mess with pulley spacing, which you will also have to do with an ATI. A stock 440 damper with stock 440 pulleys will work. Not sure if that's the best scenario for you but it will get it running. here is one from a recent thread. It looks close to a stock one but might not be....I am not sure exactly what Jesse was running on that beast. Also, some random idiot did this one with an ATI.
Rich H.
Esse Quam Videri
