Re: Milodon external oiling system
[Re: dakotahotrodder]
#2857458
12/09/20 03:41 AM
12/09/20 03:41 AM
Posts: 43,269 Bend,OR USA
Cab_Burge
I don't know all of Milidon part numbers but I have installed one of their single line external oil pickup on one of their BB/Hemi road race pans in a 1971 Challenger using a 572 pump gas Hemi EFI motor. This car has a aftermarket Oreilly tubelar front K member and their power rack and pinion steering, The car is in a body shop getting painted so no road time on it yet, I did have all the parts installed in the chassis before taking it completely apart for paint and body work I installed the single line stationary Milidon pickup on the rear of the oil pan sump near the drain plug and made my own oil line for the pickup, it looks good and has lots of clearances between the headers, motor and oil line No picture though, sorry
[Re: nss guy]
#2857560
12/09/20 11:32 AM
12/09/20 11:32 AM
Posts: 826 Georgia
66coronet
Georgia
I had to massage the steering box mounts on both our cars. Ours are a 66 coronet with the same oil system and a motor plate with TTI step headers and a 67 coronet wagon with the same oil system and a motor plate with TTI step headers.
The oil pump cover hits the steering box mounts.
[Re: nss guy]
#2857616
12/09/20 02:04 PM
12/09/20 02:04 PM
Posts: 642 South Dakota
dakotahotrodder
South Dakota
This is pretty much how I figured it should be, and will probably make as such. The kit cam with 2- 45 degree fittings and really should have either a 45 and 90, or a straight and 90. I also need to do a little removal in the steering box mount area to be sure. It is 2020, so they probably packaged it wrong. Thanks for the help and pictures!
#2857970
12/10/20 09:21 AM
12/10/20 09:21 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Here's mine on my hemi. Milodon pump w/ a stock cast iron cover and 440 Source fab'd aluminum pan. Fits w/ a completely stock K frame and doesn't loop around anything.
