Page 2 of 4 1 2 3 4
Re: Relocating battery to trunk [Re: justinp61] #2848848
11/19/20 09:55 PM
11/19/20 09:55 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by justinp61
I relocated my battery to the trunk, put it in a NHRA approved box and discovered that the battery is puking acid in the box and it's dripping out around the hold down bolts. The car has a Powermaster GM one wire alternator and according to them is functioning properly. Now I need to rethink my battery selection.
Exactly what Powermaster are you using? I see they have a version with an adjustable voltage regulator. As to voltage, 14.8 seems a little high.
Re: Relocating battery to trunk [Re: 6PakBee] #2848857
11/19/20 10:41 PM
11/19/20 10:41 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The acid is definitely coming out the vents. The voltage tests I did were with the engine running at idle and probably 4k rpms.
I'll have to check the p/n, its a cs121 gm alternator. For some reason 6030 comes to mind, I'll double check though.
Re: Relocating battery to trunk [Re: justinp61] #2848969
11/20/20 10:37 AM
11/20/20 10:37 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
That would be helpful. As a note, I tried to find the battery you are using and the closest Deka I could find in a group 24 marine starting battery was part number 24M7 at 800 CCA.
Re: Relocating battery to trunk [Re: larrymopar360] #2849166
11/20/20 05:52 PM
11/20/20 05:52 PM
Make sure and use more than one ground strap from the battery to the body, I would run one #2 from the neg. post up to the block or tranny also twocents
Re: Relocating battery to trunk [Re: 6PakBee] #2849285
11/20/20 10:16 PM
11/20/20 10:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Well I missed the p/n on the alternator, it is four digits, so I did get that right. laugh2
Re: Relocating battery to trunk [Re: justinp61] #2850340
11/23/20 11:04 AM
11/23/20 11:04 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It tested 14.7-8v at the alternator at idle and 14.8 + at I'd guess 4000 rpms, at the battery it tested 14.5-6v at idle. When I called Powermaster I gave the tech the p/n for the alternator and asked what the idle output should be? after telling him what size pulleys I'm running he said 14.8v. Then I gave him what my voltage readings were and he told me that my charging system was working perfect.
This intrigued me so I sent an email to the Deka tech line asking about allowable charging voltages for the 24M7 and here is the response:
"Good morning, the operation should be 12.6 - 12.8 , when is charging 13.5 - 14.2"
From this I think you may be overcharging your battery. You may want to check with Deka yourself as I could have misrepresented something.
Re: Relocating battery to trunk [Re: 6PakBee] #2850545
11/23/20 03:15 PM
11/23/20 03:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You may very well be right, it was my first thought too, just not thinking about the battery not being able to handle the voltage, but the alternator output being to high.
It appears I need an automotive type battery.
Thanks.
Re: Relocating battery to trunk [Re: justinp61] #2850625
11/23/20 06:09 PM
11/23/20 06:09 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm not so sure that an automotive battery is the answer. 14.8 volts is a fairly high charging voltage. I would recommend you review the following document.
A GUIDE TO BATTERY CHARGING
An excerpt from that is "Although a battery is called a '12 volt' battery, its voltage varies from about 12.6 volts down to 10 volts when it is discharging and can rise to 15 or 16 volts during charging. It is very important, however, to limit the maximum battery voltage during charging otherwise the battery will be damaged. The battery voltage should not exceed 13.8 volts for long periods and 14.4 volts for short periods (8 hours maximum)"
Re: Relocating battery to trunk [Re: Cab_Burge] #2851110
11/24/20 09:14 PM
11/24/20 09:14 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
Re: Relocating battery to trunk [Re: 6PakBee] #2851116
11/24/20 09:19 PM
11/24/20 09:19 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
13.8 TO 14.2 is what i was taught, anything over 14.5 is starting to get a little ti high IMO. one has to make sure grounds, accumulative V drops or the V regulator are not what's
over driving the charging rate twocents
Re: Relocating battery to trunk [Re: TJP] #2856850
12/07/20 11:00 PM
12/07/20 11:00 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
I like the Ford solenoid in the trunk idea too. It will make the heavy starter wire dead until cranking. You will then need to jump the small to big lead on your starter.
To be NHRA legal, you will need to cut the charging system with a switch at the back of the car. I have done this a couple times in the past by running the charge wire through the switch but you lose alot of charge voltage running the wire the length of the car twice. If I was to do that again. I'd use the switch to interuppt the field circuit.
Re: Relocating battery to trunk [Re: Magnum] #2857047
12/08/20 01:10 PM
12/08/20 01:10 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
be careful switching on and off an alt. field, it can act like a coil inducing a voltage spike on your ignition circuit. There is right and wrong ways to do it. Guess which way I came up with. eek
Re: Relocating battery to trunk [Re: B1MAXX] #2857077
12/08/20 02:05 PM
12/08/20 02:05 PM
IMGTX Offline
IMGTX  Offline
Would it meet the Regulations to disconnect the power output of the alternator by de-powering a relay at the front of the car from the switch at the back of the car? It would just be matter of getting a high amp relay.
I do not know if it would meet specs. shruggy
Re: Relocating battery to trunk [Re: IMGTX] #2857179
12/08/20 04:37 PM
12/08/20 04:37 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
So you all are saying a gel car battery needs to be vented also? I`m asking because I don`t know. What about the ones that are sealing the small gel battery inside a old resto battery case like others here have done?
Re: Relocating battery to trunk [Re: mopars4ever] #2857260
12/08/20 07:12 PM
12/08/20 07:12 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I believe so. The factory battery in my Charger is a gel I believe, and vented.
Facts are stubborn things.
Re: Relocating battery to trunk [Re: B1MAXX] #2857552
12/09/20 11:03 AM
12/09/20 11:03 AM
Magnum Offline
Magnum  Offline
I scrolled up and I guessed which way you came up with but still do not know.
Re: Relocating battery to trunk [Re: Magnum] #2857598
12/09/20 01:10 PM
12/09/20 01:10 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have a switch on the alternator field circuit on my race car. With the ignition on if you throw the switch the indicator light I have on the switch flashes very bright, and you get whacked on your finger. I'm no electrical eng. but it has to do with a DC inductive field collapsing like a coil, the winding are the alt field winding.I could probably wire it differently(than the way I came up with)but we just don't touch the switch anymore. It's ok to turn it off and on before the ignition. But if you turn it off with the field energized you get whacked.
Re: Relocating battery to trunk [Re: B1MAXX] #2857604
12/09/20 01:22 PM
12/09/20 01:22 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I recommend a Transorb or other transient surge suppressor to snub the overvoltage spike...
https://en.wikipedia.org/wiki/Transient_voltage_suppressor
Re: Relocating battery to trunk [Re: DrCharles] #2857630
12/09/20 02:31 PM
12/09/20 02:31 PM
moparx Offline
moparx  Offline
i was strongly considering relocating the battery to the trunk of my charger, but seeing the inner fender under the battery tray is crusted up because of battery acid and gasses, thus needing repair, i'm now thinking i will modify that area for one of those light weight tiny AMG batteries.
beer.
Re: Relocating battery to trunk [Re: moparx] #2858928
12/12/20 12:49 PM
12/12/20 12:49 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
beer.
Hopefully the box will protect any type of leakage. I really want the weight transfer. I didn't know the AMG batteries were that small and light weight.
Page 2 of 4 1 2 3 4
