Instrument Panel Lighting E-body
#2856545
12/07/20 01:47 PM
12/07/20 01:47 PM
Posts: 2,332 Addison Twp, Mi.
RobG
Addison Twp, Mi.
Has anyone found a brighter - maybe LED bulb that can be substituted for the instrument panel bulbs?
Any recommendations?
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
Re: Instrument Panel Lighting E-body
[Re: roadrunninMark]
#2857941
12/10/20 05:57 AM
12/10/20 05:57 AM
Posts: 1,978 USA
Suregrip391
USA
I did the conversion years ago but I’m sorry to say I lost the list of bulbs used. I can say it’s worth the effort though....
They are actually too bright, but dim to a perfect level.
[Re: Suregrip391]
#2857966
12/10/20 09:14 AM
12/10/20 09:14 AM
Posts: 4,727 Florida
BDW
You have to be careful when picking LED colors if you want to match original light color. Incandescent bulbs have yellow tint. I originally bought white LEDs and my dash lights were Blue. E-bodies have Blue lenses that when combined with the Yellow bulb give a Green color. I now have Yellow LEDs and now my color matches the Green I wanted.
[Re: BDW]
#2858155
12/10/20 05:04 PM
12/10/20 05:04 PM
RobG
Addison Twp, Mi.
Wow , Just the brightness I was expecting to see. Thanks everyone.
#2858248
12/10/20 08:42 PM
12/10/20 08:42 PM
Posts: 1,978 USA
Suregrip391
USA
In my pic above, I do remember mine were green. You want a wider angle led bulb too. Not one with a narrow focal point. That will give you a bright center with side shadows on your gauges. Remember, led bulbs are directional and shine straight like a flashlight. An incandescent bulb lights up all around the bulb surface. I got my bulbs from https://www.superbrightleds.com/ using the cross reference from numbers off the original bulbs. You also have to measure your old bulbs up to make sure the new ones will fit in the smaller places you need them. Led bulbs tend to run larger in length and diameter. Have that info handy and spend some time on their site finding a suitable bulb that will physically fit. Key points: Length of bulb Width of bulb Angle ( if needed to shine in the direction desired) Use the same color bulb for the same color lens it shines through
[Re: RobG]
#2862655
12/20/20 06:26 PM
12/20/20 06:26 PM
Posts: 1,111 Usa
A39Coronet
Usa
Sorry to dig this up but I figured I'd share this pic. Here is a comparison between original incandescent bulbs and BA9S white LED behind the blue filter in the dash. Definitely a color difference with the originals being much more green vs the straight blue if the LED. I'd be curious to see how close the yellow LEDs are to the original color. As you could probably imagine there is a fairly substantial temperature difference between the two housings even after on a few minutes.
