Is the engine centered in the chassis ? #2856006
12/06/20 01:10 PM
12/06/20 01:10 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
This would be E-body, big block, and normal engine mounts, K-member.
How about the tranny mount, that looks centered to me (?), I guess.
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856044
12/06/20 01:41 PM
12/06/20 01:41 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Nope ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856053
12/06/20 02:00 PM
12/06/20 02:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its bias to the right ABOUT 1.5 inches (pass side) on a production car for foot room
wave
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856057
12/06/20 02:04 PM
12/06/20 02:04 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
No, it's over to the pass side by about an Inch, Plays havoc with my OCD now I've cut a hole in the hood for the T/R. mad I don't think the trans is central either smirk
Re: Is the engine centered in the chassis ? [Re: MR_P_BODY] #2856060
12/06/20 02:07 PM
12/06/20 02:07 PM
wave
iagree scope
If you move it over more it helps balance the chassis so you get more weight onto the right rear up
Every stock or semi stock Mopar car I have weighed all four corners without the driver had the most weight on the left front, RF was next in weight The LR was lighter than the RF but heavier than the RR whiney Installing batteries in the trunk helps but more weight is better on the right rear up
Re: Is the engine centered in the chassis ? [Re: MR_P_BODY] #2856062
12/06/20 02:08 PM
12/06/20 02:08 PM
Washington
Washington
OK, thanks guys. I'm doing a bunch of reading right now about pinion offset
and related. It seems that the "stock" Mopar pinion offset puts both the
pinion and the driveshaft in the center of the tunnel, BUT, the whole tunnel is
actually offset in the body/frame. AND the engine is offset.
This sound about right ?
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856070
12/06/20 02:37 PM
12/06/20 02:37 PM
gregsdart Offline
gregsdart  Offline
Yes. I built my drag car with 1 inch offset. Or you can measure the pinion offset and use that.
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856072
12/06/20 02:47 PM
12/06/20 02:47 PM
A lot of the production 1960 and 1970 B body cars I've measured the crankshaft on look like they are closer to 1 3/4 to 2 1/4 inches to the passenger side scope
The engine and driveline torque rotate to the passenger side clockwise (looking from the front of the engine to the rear of the cars) but the engine rotation puts more pressure on the left rear tire than the right rear tire, it is trying to lift the right rear tire up instead of pushing it down whiney Hence the driver side axle breaking sooner and more often than the passenger side. Same thing on breaking the driver side carrier caps on rear ends work scope
Re: Is the engine centered in the chassis ? [Re: Cab_Burge] #2856089
12/06/20 03:12 PM
12/06/20 03:12 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just measure the tunnel from each side, it’s not centered. Pass side Hemi cover is tight, driver side has a lot more room, measure that to tell how much engine is to the right. (All engines will be the same) Pinion is not centered either
Re: Is the engine centered in the chassis ? [Re: cudaman1969] #2856101
12/06/20 03:26 PM
12/06/20 03:26 PM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Offset is 1” toward the passenger side.
Re: Is the engine centered in the chassis ? [Re: Cab_Burge] #2856102
12/06/20 03:26 PM
12/06/20 03:26 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The driveline - center of the crankshaft bolt to the center of the pinion shaft - should be straight, as far as side to side, and parallel to the chassis centerline.
The A Body stuff I've dealt with was like an 1 1/4". And I believe that number holds pretty close for the other chassis. Tolerances being what they were, that 1 1/4" could be +/- 1/8 or more. Drop stringlines and get it as close as you can.
If you're using all OE mounting, not much you can do with it. Maybe fudge the trans one way or the other.
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856152
12/06/20 05:31 PM
12/06/20 05:31 PM
AndyF Offline
AndyF  Offline
Mopar cars are offset. The actual amount of offset depends on make, model and year. There is no one number for all cars. TTI has the best list of offsets that I've seen published on their website. I use the TTI offset guide when I design parts.
Re: Is the engine centered in the chassis ? [Re: AndyF] #2856154
12/06/20 05:39 PM
12/06/20 05:39 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I centered my motor in my 64 Belvedere after a few "friends " badgered me into .. sounded easy but, its not .
For every action, there is a opposite and equal reaction
Sir Isaac Newton
Re: Is the engine centered in the chassis ? [Re: bigdad] #2856217
12/06/20 07:46 PM
12/06/20 07:46 PM
AndyF Offline
AndyF  Offline
Yeah I consulted with a race team on a Mopar they were building. They were Chevy guys and they wanted the engine in the center of the car so that is what they did. Then they had to buy two sets of floor panels to patch the floor and change the firewall and they had to modify the trans mount and the torsion bar cross member and all of that. But in the end they were happy since it looked correct to them.
Re: Is the engine centered in the chassis ? [Re: AndyF] #2856252
12/06/20 09:02 PM
12/06/20 09:02 PM
Sticky South
Rodenteliminator Online content
Rodenteliminator  Online Content
Sticky South
How much offset would one dare go with if you haven’t started the process of engine position forward or aft or offset with a front and mid plate on a Bbody and a low deck wedge?Rearend has not been spec,d either so the slate is clean. Thanks DK I should add headers will not an issue as they will be fender well headers.
Sorry honey I spent the rent
Re: Is the engine centered in the chassis ? [Re: Rodenteliminator] #2856269
12/06/20 09:40 PM
12/06/20 09:40 PM
AndyF Offline
AndyF  Offline
If it is a stock floor car with a stock firewall then I'd put the engine and trans in the factory location. If it is a tube chassis car then put stuff where you want it.
Re: Is the engine centered in the chassis ? [Re: AndyF] #2856294
12/06/20 10:30 PM
12/06/20 10:30 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
hings that you never even think of , get in the way .. oil filter vs lower radiator hose , I had to fight the throttle linkage cause then it hit firewall , headers where a S ob .. i had to make a slip tube on two tubes , thats just a few things , it was a pita
Re: Is the engine centered in the chassis ? [Re: hemienvy] #2856514
12/07/20 12:52 PM
12/07/20 12:52 PM
central il.
second 70 Offline
second 70  Offline
central il.
Here's a picture showing the offset to get the shaker in the middle of the hood on a my Hemi Cuda .Engine almost hits on right side. This is factory location. The steering column wouldn't fit if centered.
and another showing the offset of the oil pan looking at front of car.
119997098_10215018493770907_5451680637964279881_o.jpgIMG_0630-1.jpg69755284_2669205743099202_8127883788412780544_o.jpg
Re: Is the engine centered in the chassis ? [Re: second 70] #2856543
12/07/20 01:45 PM
12/07/20 01:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
When we did our chassis car, the driveline was put in 1" to the right. A little extra room for the driver. Desired corner weights and balance easy to achieve with minimal preload or spring manipulation from neutral. It worked well. It wasn't a big power deal. If it is i would want the stuff centered.
Stock floor, stock trans mount, stock K frame, steering, etc, I would put it in factory location. Super Stock Hemis are done that way and they work just fine. The whole engine/trans assembly can be moved back and/or down with some changes to the trans mount, if using motor plates. That would be more beneficial than spending a bunch of effort getting everything in the center. Removable/custom trans tunnel is likely needed to accomplish that. Headers on the left side with stock steering is always a challenge.
Re: Is the engine centered in the chassis ? [Re: CMcAllister] #2856561
12/07/20 02:03 PM
12/07/20 02:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As stated factory bias is about 1.5" to the pass side. Footwell, steering box clearance is why as Ive heard both.
