Re: 426 Hemi ratroaster linkage
[Re: Hemidavey]
#2855485
12/04/20 10:52 PM
12/04/20 10:52 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Good luck on that How is your fab skills on making parts like that I built a 383 motor with a similar Eddy STR (Street Tunnel Ram) back in the early 1970s, the owner furnish the intake and either dual 600 or 650 Holley Double pumper carbs and Eddy linkage for mounting them like a cross ram with the carbs pointed straight ahead and not sideways. That combination with a stock 1962 12 inch Mopar converter with 2.73 gears and short tires in the 1963 Dart 270 was a real dog under 3000 RPM and then it was like a rocket booster up to over 7500 RPM It needed a decent upgraded complete fuel system and converter to be as good as it could have been, live and learn
[Re: Hemidavey]
#2855564
12/05/20 08:29 AM
12/05/20 08:29 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I will take an overhead picture to show the linkage I made for it. I used some parts available from A&A that are for the factory cross ram . I used stainless to make the rods and purchased the ends. These are the 4235 and 4236 carbs.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2855570
12/05/20 08:45 AM
12/05/20 08:45 AM
Hemi Allstate
Mt. Eden Ky.
This is from my phone. My camera is not here , but I will take more pictures if you need them . IHTH.
Mark
[Re: Hemidavey]
#2856125
12/06/20 04:07 PM
12/06/20 04:07 PM
Hemi Allstate
Mt. Eden Ky.
Hemidavey . You are welcome . I don't know how to tell which end is which on the bottom part of the manifold. I would like to see the picture you have of the one with the F . If it was inside , then I may have ground it off since, I did a lot of grinding on the inside . I don't remember seeing it. I have not tried this setup. I suspect it would not have great street manors, and I have been going to shows and not racing the last couple years. It would be tough to use carbs, and make linkage for models other than the race Hemi ones because of the linkage arms on the Hemi carbs being on both sides. Mark
[Re: Hemidavey]
#2856938
12/08/20 09:05 AM
12/08/20 09:05 AM
Hemi Allstate
Mt. Eden Ky.
I don't remember seeing that on mine . I do have a case of CRS these days. I need to review some pictures I took before I modified my intake. They are on another computer that is not functioning properly, so that may be a problem . Thanks !
Mark
