Closed loop fueling not achieved Check eng light #2855183
12/04/20 12:00 PM
12/04/20 12:00 PM
Penna
70satelliteguy Offline OP
Penna
2007 2500 5.7 hemi check engine light .
No symptoms, anyone have this code and fixed it?
Mike
Re: Closed loop fueling not achieved Check eng light [Re: 70satelliteguy] #2855191
12/04/20 12:19 PM
12/04/20 12:19 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Make sure it is heating up fast enough. Weak thermostat can cause this. Engine has to heat from point a to b in a specific time. If the temperature is not achieved a code can be set.
Re: Closed loop fueling not achieved Check eng light [Re: NITROUSN] #2855194
12/04/20 12:33 PM
12/04/20 12:33 PM
Penna
Penna
Thanks for the reply . I reset the light and if it comes back on I will check .
Mike
Re: Closed loop fueling not achieved Check eng light [Re: 70satelliteguy] #2856065
12/06/20 02:19 PM
12/06/20 02:19 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
Replace thermostat with OES unit only.
Re: Closed loop fueling not achieved Check eng light [Re: ditchdrift] #2856534
12/07/20 01:31 PM
12/07/20 01:31 PM
Penna
Penna
I turned off the light and it has not come back on so far!
Mike
