Oil Pump Gasket #2854142
12/02/20 06:38 AM
12/02/20 06:38 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
When replacing a big block oil pump, do I need to use a sealant on the gasket?
Re: Oil Pump Gasket [Re: elmor353] #2854149
12/02/20 08:06 AM
12/02/20 08:06 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I assume we are talking the gasket against the block? sealant is not necessary, however I use a thin coat of Hi Tack to prevent seepage. Never use silicone, it will find its way into the oil passage hole...way too thick!
Re: Oil Pump Gasket [Re: elmor353] #2854217
12/02/20 10:47 AM
12/02/20 10:47 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The Mopar Engine Manual says no.
2011 Drag Pak Challenger
Re: Oil Pump Gasket [Re: elmor353] #2854220
12/02/20 10:59 AM
12/02/20 10:59 AM
A727Tflite Offline
A727Tflite  Offline
The ”O” rings do all the work.
The gasket is “suspenders on a belt”.
Looking at the other post about bronze gear wear I wonder how much impact if any there is by using no gasket, thin gasket versus thick gasket.
Makes you wonder.
Re: Oil Pump Gasket [Re: A727Tflite] #2854405
12/02/20 03:29 PM
12/02/20 03:29 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Originally Posted by Transman
[quote=elmor353]Looking at the other post about bronze gear wear I wonder how much impact if any there is by using no gasket, thin gasket versus thick gasket.
Makes you wonder.
My guess would be little to none. The hex end of the intermediate shaft slides freely down into the pump--it does not (or should not grin) bottom out. So regardless of where the pump itself sits, the bottom of the drive gear will settle down onto the top of the intermediate shaft bushing. This is what locates the point where the gears mesh--not the location of the pump.
But that's just me spitballin'...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Oil Pump Gasket [Re: wingman] #2854413
12/02/20 03:40 PM
12/02/20 03:40 PM
A727Tflite Offline
A727Tflite  Offline
Makes you wonder.
Makes sense.
Re: Oil Pump Gasket [Re: A727Tflite] #2854462
12/02/20 06:14 PM
12/02/20 06:14 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I didn't think a sealant was necessary, but when looking for torque specs, the Hayne's manual said to put a thin layer of RTV on the gasket. I had never done that before and I have seen other things in these manuals that have made me scratch my head and go huh? I can see using some hi tack, so I will use some. The Melling gasket kit that I've got didn't come with the large o-ring, just the gasket and o-ring for the neck of the pump.
Re: Oil Pump Gasket [Re: elmor353] #2854607
12/02/20 11:08 PM
12/02/20 11:08 PM
I didn't think a sealant was necessary, but when looking for torque specs, the Hayne's manual said to put a thin layer of RTV on the gasket. I had never done that before and I have seen other things in these manuals that have made me scratch my head and go huh? I can see using some hi tack, so I will use some. The Melling gasket kit that I've got didn't come with the large O-ring, just the gasket and O-ring for the neck of the pump.
That is what you need, the two O rings in the pump should be in the pump, not needing to be installed in the pump before installing the pump
I have used Gasket cinch on the pump body and pump gasket to hold the gasket in place while installing the pump, I did not use silicone gasket maker type on the pumps or gaskets tsk
The new Milidon race oil pumps now come with O rings only and no gaskets up That has worked very well for me on the last 4 or 5 race motors that I used Milidon external oiling systems on up Very Well up
