Leaf Spring slider Tech
#2853573
11/30/20 09:45 PM
11/30/20 09:45 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Time to try something new...looking to improve the 60 ft of the car substantially... these are manufactured by LP racing... the current sliders are bolt in so I can always go back if things do not play nicely
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Leaf Spring slider Tech
[Re: RATTRAP]
#2854375
12/02/20 02:32 PM
12/02/20 02:32 PM
Posts: 4,673 On the parachute mount
n20mstr
thats crazy , i would imagine thats really going to stand up the back of the car. Looking forward to how it works.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2854446
12/02/20 05:22 PM
12/02/20 05:22 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
not a fan of that design.
JAKES AUTOMOTIVE
[Re: WHITEDART]
#2854514
12/02/20 07:33 PM
12/02/20 07:33 PM
Posts: 54 VA Beach, VA
Runnoft
VA Beach, VA
Time to try something new...looking to improve the 60 ft of the car substantially... these are manufactured by LP racing... the current sliders are bolt in so I can always go back if things do not play nicely I've seen a couple of people try them out somewhat successfully although I'm not convinced they are better than a conventional slider. Tom Barton had them on Nova here on the east coast that runs 4.40's in the eighth and ended up going back to the 10 degree slider. Armen Maghdessian had them on his car in Vegas two weeks ago and they worked great BUT that track was so tight everyone was going personal best 60's. Regardless, I don't think they are an easy bolt on and forget it part - the shock tuning is going to be critical to making the whole thing work. The other thing is - the cars trying to use these are probably 2000+ horsepower combos or close to it. I run leafs and have been in the 1.0 sixty range probably 10 times and have run a 1.06 sixty three times. That's my best so far and I use a 10 degree slider set up. I like the out-of-the-box thinking behind these for sure.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116. Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
[Re: n20mstr]
#2854623
12/02/20 11:58 PM
12/02/20 11:58 PM
WHITEDART
bean town ....Ca
Hopefully I will have good information to report back I just didn't feel I could sit here without trying it...
[Re: Runnoft]
#2854624
12/03/20 12:09 AM
12/03/20 12:09 AM
WHITEDART
bean town ....Ca
Time to try something new...looking to improve the 60 ft of the car substantially... these are manufactured by LP racing... the current sliders are bolt in so I can always go back if things do not play nicely I've seen a couple of people try them out somewhat successfully although I'm not convinced they are better than a conventional slider. Tom Barton had them on Nova here on the east coast that runs 4.40's in the eighth and ended up going back to the 10 degree slider. Armen Maghdessian had them on his car in Vegas two weeks ago and they worked great BUT that track was so tight everyone was going personal best 60's. Regardless, I don't think they are an easy bolt on and forget it part - the shock tuning is going to be critical to making the whole thing work. The other thing is - the cars trying to use these are probably 2000+ horsepower combos or close to it. I run leafs and have been in the 1.0 sixty range probably 10 times and have run a 1.06 sixty three times. That's my best so far and I use a 10 degree slider set up. I like the out-of-the-box thinking behind these for sure. . Just looking for a little more rear travel.. figured it would be worth a try... definitely some challenges ahead. Hopefully a quality science experiment
[Re: justinp61]
#2854625
12/03/20 12:10 AM
12/03/20 12:10 AM
WHITEDART
bean town ....Ca
At least the tires should be easier to get off the car. .. I can only hope it's almost impossible to get the tires off now
[Re: n20mstr]
#2854626
12/03/20 12:13 AM
12/03/20 12:13 AM
WHITEDART
bean town ....Ca
thats crazy , i would imagine thats really going to stand up the back of the car. Looking forward to how it works. . Controlling the hit has been the challenge... if I can get the timing and sooner without running out of rear travel I can see positive results and this song but by but absolutely no it's only going to be a learning curve
[Re: RATTRAP]
#2854742
12/03/20 11:29 AM
12/03/20 11:29 AM
Posts: 4,206 New York
polyspheric
New York
That price is their R&D cost
Boffin Emeritus
[Re: WHITEDART]
#2854756
12/03/20 12:13 PM
12/03/20 12:13 PM
JAKE68
Shelby mi.
Time to try something new...looking to improve the 60 ft of the car substantially... these are manufactured by LP racing... the current sliders are bolt in so I can always go back if things do not play nicely I've seen a couple of people try them out somewhat successfully although I'm not convinced they are better than a conventional slider. Tom Barton had them on Nova here on the east coast that runs 4.40's in the eighth and ended up going back to the 10 degree slider. Armen Maghdessian had them on his car in Vegas two weeks ago and they worked great BUT that track was so tight everyone was going personal best 60's. Regardless, I don't think they are an easy bolt on and forget it part - the shock tuning is going to be critical to making the whole thing work. The other thing is - the cars trying to use these are probably 2000+ horsepower combos or close to it. I run leafs and have been in the 1.0 sixty range probably 10 times and have run a 1.06 sixty three times. That's my best so far and I use a 10 degree slider set up. I like the out-of-the-box thinking behind these for sure. . Just looking for a little more rear travel.. figured it would be worth a try... definitely some challenges ahead. Hopefully a quality science experiment don't know why you would want more travel. That is not the most desirable action you want. we usually stiffen the shocks to control that. you want it to pitch and rotate. With that set up you drive the ic way up. what kind of power you making if your sixties are 1.06. that is faster than an ss/ah car.
JAKES AUTOMOTIVE
[Re: polyspheric]
#2854795
12/03/20 01:35 PM
12/03/20 01:35 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
That price is their R&D cost We the customers are thier R&D product testors.
[Re: JAKE68]
#2854882
12/03/20 05:44 PM
12/03/20 05:44 PM
Posts: 9,825 MI, usa
dvw
MI, usa
don't know why you would want more travel. That is not the most desirable action you want. we usually stiffen the shocks to control that. you want it to pitch and rotate. With that set up you drive the ic way up. what kind of power you making if your sixties are 1.06. that is faster than an ss/ah car. [/quote]
This is a Pro Radial style tire. If you can separate the housing further you can keep adding load to the tire. And you have a shock with the ability to control the speed at which this happens, my bet is you can ramp in power earlier. Doug
[Re: dvw]
#2854899
12/03/20 07:08 PM
12/03/20 07:08 PM
n20mstr
don't know why you would want more travel. That is not the most desirable action you want. we usually stiffen the shocks to control that. you want it to pitch and rotate. With that set up you drive the ic way up. what kind of power you making if your sixties are 1.06. that is faster than an ss/ah car. This is a Pro Radial style tire. If you can separate the housing further you can keep adding load to the tire. And you have a shock with the ability to control the speed at which this happens, my bet is you can ramp in power earlier. Doug [/quote] It will be interesting to see if this slider shows up on other radial tire cars. THe ability to have a "moving" IC is very helpful, As the Fox body mustang has
[Re: RATTRAP]
#2854919
12/03/20 08:05 PM
12/03/20 08:05 PM
polyspheric
New York
So what you're buying is one shot from the sketch on the cocktail napkin straight to the welder with no testing?
Boffin Emeritus
[Re: dvw]
#2854929
12/03/20 08:29 PM
12/03/20 08:29 PM
Posts: 1,111 Usa
A39Coronet
Usa
This was my exact thoughts as well Doug, that this setup was only intended for cars that are ramping in timing and power well after the initial hit. I'm not familiar with OPs car, so hopefully that's what he's doing.
[Re: dvw]
#2854978
12/03/20 09:54 PM
12/03/20 09:54 PM
WHITEDART
bean town ....Ca
don't know why you would want more travel. That is not the most desirable action you want. we usually stiffen the shocks to control that. you want it to pitch and rotate. With that set up you drive the ic way up. what kind of power you making if your sixties are 1.06. that is faster than an ss/ah car. This is a Pro Radial style tire. If you can separate the housing further you can keep adding load to the tire. And you have a shock with the ability to control the speed at which this happens, my bet is you can ramp in power earlier. Doug [/quote] 1.15. Is our best so far . And yes it is a tick faster then in SSHA car.. naturally aspirated small block on a 28-10.5 Tire we do not want to pitch rotate in radial tire trim..
