Seeing as my manual gear box is toast in this thing and I'm wanting to go Power assist, a lot of the swap info ..well, swaps over to the vans since they use mostly passenger car components.
I'm a little rusty though, seeing as I have a manual steering column, i can cut the shaft down and reapply to pin for the coupler, correct? I just need to figure the right 'new' length
the Pitman arm that came off the manual box actually has "MANUAL" stamped in it, but it fits the power box I have, and it's the same length as the unknown arm that was on it.
Besides that, I just need to gather up a few more parts.
Any info of the pitman arm and steering shaft is greatly appreciated.
