Re: Hemi valve cover gasket/rocker clearance under valve cover
[Re: Paul_B]
#2853112
11/29/20 08:33 PM
11/29/20 08:33 PM
Posts: 15,357 Omaha Ne
TJP
Omaha Ne
Shouldn't be a problem. We had one recently that the baffle came loose and was hanging by one spot weld. NICE They do make thicker gaskets and I do have a pair. that I don't need as I sold the car. They are Fel pros I believe, cork and I'm guessing either 3/16 or 1/4 " thick PM me if your interested
[Re: Paul_B]
#2853248
11/30/20 09:57 AM
11/30/20 09:57 AM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I had the exact situation on my Hemi. Tighten them down to stop leaks, and then get tapping. On mine, it was the exhaust rockers hitting the valve cover itself. Double gaskets didn't fix it. Ended up dimpling the valve covers at the points of contact and refinishing them and adding the extra gaskets. The hard Superformance gaskets helped because they don't crush as much as the cork or rubber ones do. But I had to trim them to fit.
I also used valve cover bolt brackets. Had to trim them to fit but when I painted them to match the valve cover finish, you don't notice them. On my steel covers, they really helped to reinforce that area and spread the load so that I could pull the valve covers down tighter.
Master, again and still
