trans cooler lines size
#2852822
11/29/20 09:31 AM
11/29/20 09:31 AM
Posts: 458 somewhere out there
Billy no mates
somewhere out there
Guys Looking for some information please,
I'm wanting to make my own trans cooler lines on my 64 Dodge can anyone confirm the size of the lines & where I can purchase the unions for the ends please.
thanks Billy
BillyNoMates
Re: trans cooler lines size
[Re: TJP]
#2853205
11/30/20 02:16 AM
11/30/20 02:16 AM
Posts: 1,820 South Bend
John Brown
South Bend
the cooler lines are 5/16" and the nuts/fittings should be common parts store items. I'm not too sure the Female inverted flare nuts are going to be available at the local parts house. most around here don't carry a lot fitting wise Usually compression fitting union nuts will work fine.
[Re: Billy no mates]
#2853377
11/30/20 02:54 PM
11/30/20 02:54 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
They are 5/16 outside diameter close to 1/4 inside diameter. # 4 or 5 AN should work well also
