Ultrasonic carb cleaning #2852160
11/27/20 01:01 PM
11/27/20 01:01 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
What is a good solution to use for cleaning carbs? Thanks.
Re: Ultrasonic carb cleaning [Re: MO_PA] #2852198
11/27/20 02:17 PM
11/27/20 02:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I would contact Crest Ultrasonics, they supply Industrial grade solutions for specific alloys, any thing you buy at parts stores will be junk...
Re: Ultrasonic carb cleaning [Re: DAYCLONA] #2852200
11/27/20 02:22 PM
11/27/20 02:22 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks DAYCLONA
Re: Ultrasonic carb cleaning [Re: MO_PA] #2852239
11/27/20 03:55 PM
11/27/20 03:55 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I've been using Evaporust with success. It's about $20/gallon though.
Re: Ultrasonic carb cleaning [Re: MO_PA] #2852242
11/27/20 04:02 PM
11/27/20 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Before you buy expensive cleaners, try tap water with a little Dawn dishwashing detergent added.
Re: Ultrasonic carb cleaning [Re: John_Kunkel] #2852265
11/27/20 04:52 PM
11/27/20 04:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Evaporust is about $15 a gallon on Amazon.
Re: Ultrasonic carb cleaning [Re: mopars4ever] #2852270
11/27/20 05:00 PM
11/27/20 05:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
When I was working for a company making small ultrasonic cleaners, we used ammonia. You want to have the water at least 130 degrees. Don't leave it in the cleaner very long. Max 5 minutes. Remember the ultrasonic attacks aluminum. In my 30 gallon cleaner it will make holes in aluminum foil in 20 seconds.
Dawn would be my second choice for a small cleaner.
Re: Ultrasonic carb cleaning [Re: markz528] #2852305
11/27/20 07:38 PM
11/27/20 07:38 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
My cleaner only holds about 2 gallons, it won't break the bank to try different solutions. Thanks guys.....
Re: Ultrasonic carb cleaning [Re: MO_PA] #2852313
11/27/20 08:13 PM
11/27/20 08:13 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have two ultrasonic tanks. most of the time i use pine-sol and water. Big zip lock bag, put the carb in, then fill the bag with pine sol and water and seal the bag dirty water stays in the bag and keeps your tank clean. keeping it in the bag you can adjust the mix. do not use citrus based cleaners on aluminum.
lots of different stuff on the net for stuff to use. i have had great results with pine sol and its cheap.
Re: Ultrasonic carb cleaning [Re: chrisf] #2852382
11/27/20 10:31 PM
11/27/20 10:31 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
I Had been using this stuff http://www.kleenflo.com/products/651-652-653.html but it is no longer available in Canada. Not sure about the US. Worked great but Pretty nasty stuff!!!
Now using this in my ultrasonic cleaner. https://gunk.com/product/gunk-hydro-seal-ii-heavy-duty-parts-cleaner-hs3c/ Not as good, and not as nasty!!!
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Ultrasonic carb cleaning [Re: RealWing] #2852427
11/28/20 01:57 AM
11/28/20 01:57 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Chemicals can break down in ultrasonic cleaners and form toxic gasses. I'd hate to hear of anyone getting a case of the deads from not reading the precaution labels.
Re: Ultrasonic carb cleaning [Re: John Brown] #2853707
12/01/20 09:51 AM
12/01/20 09:51 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I use a mix of “LA’s Totally Awesome” from the dollar tree in mine. Works excellent.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Ultrasonic carb cleaning [Re: mopardude318] #2853736
12/01/20 11:05 AM
12/01/20 11:05 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've tried a dozen suggestions from various forums trying to save money on ultrasonic soap but none of them have worked for me. I get great results buying the real stuff from someone that sells ultrasonics. Remember, different metals might require different soap. On old Holley carbs the throttle plate is aluminum but the rest is zinc.
2011 Drag Pak Challenger
Re: Ultrasonic carb cleaning [Re: rickseeman] #2853937
12/01/20 06:37 PM
12/01/20 06:37 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I used simple green and water on my 51 Plymouth's B&B when I rebuilt it.
Worked fine, but it wasn't plugged up either.
Re: Ultrasonic carb cleaning [Re: John_Kunkel] #2854935
12/03/20 08:36 PM
12/03/20 08:36 PM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
This and HOT water. Use it for gun parts all the time as well.
