Wiped Cams #2852260
11/27/20 04:40 PM
11/27/20 04:40 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
So a member here was interested in my old Mopar Performance / Direct Connection 509 cam. I ran this cam for a short while in the 80's in a stock bottom end 440 with home ported 906 heads (I did not do good work back then). In race trim the 67 Coronet went 11.70's. I was happy. Then I built a new motor and this cam stayed in the short block for decades. I had run 20w-50 Kendall oil in it.
I take the cam off the shelf and it looks purty darn good till I measure the lobes in the lathe. Its really bad. When I really looked at it close I could visually see some rounded lobes - at first glance I missed it.
Fast forward a few months. I find another 509 cam hanging in the garage. No idea where it came from but its been there around 25 years - that's when I put the shelves up and tucked the cam away. It looked even better. Back in the lathe and lo and behold 2 wiped lobes. One 0.036" and the other 0.062". WTH?
I always thought I was totally successful with my hydraulic cams back in the day. My paradigm is shot. Anyone else have similar experiences on old school cams and oil? Here I thought it was just a new era phenomenon............ I have a couple more used cams in the basement. I will measure those too just to see.
Re: Wiped Cams [Re: markz528] #2852279
11/27/20 05:35 PM
11/27/20 05:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I have a 509 from about 30 years ago that a friend ran for 2 seasons of bracket racing.
I don’t know what he ran for springs, but probably the 933 springs, which are a pretty high rate spring, that don’t have a lot of extra space til coil bind if installed at the stock 1.860 installed height and opening to .500” lift.
If the installed height is a little short, I can see that leading up to accelerated wear.
It was given to me, I looked it over quick....... saw nothing obvious at that time.
If I get a chance I’ll measure it up this weekend.
Re: Wiped Cams [Re: markz528] #2852308
11/27/20 07:48 PM
11/27/20 07:48 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I mark my pushrods and make sure they are spinning while rolling the crank. I'm told the lifter is always the cause of wiped cams and the cam has nothing to do with it. Howards also told me nitrating is a waste of money and someone just taking your money because of this. check your lifters and make sure they spin while cranking. EDM lifters with good oil high in zinc and phosphate as well.
Re: Wiped Cams [Re: mopar dave] #2852353
11/27/20 09:34 PM
11/27/20 09:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Absolutely, positively........ not true.
If the cam is ground with inadequate lobe taper, causing the lifters to not turn...... how is that not a cam problem?
I’ve seen that situation many many times.
Or the guy over on FABO that had the SBM Hughes cam(ground at Howard’s) that had .007(7 thou) lobe taper that had the lobes chipping away from the edge loading.
Again...... not a lifter problem.
This lifter came off a hyd cam that had under a half thou lobe taper:
No taper...... no spin.
Re: Wiped Cams [Re: fast68plymouth] #2852418
11/28/20 12:46 AM
11/28/20 12:46 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Can we invent a lifter with an oil band turbine so it rotates on the base circle no matter what laugh
Re: Wiped Cams [Re: fast68plymouth] #2852469
11/28/20 09:52 AM
11/28/20 09:52 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Looks like lifters should always be checked. https://youtu.be/9EBsMqqu8Bo
I believe what the gentleman at Howards was saying is a cam with a good core and properly machined would not be the fault of its own if it lost a lobe. The gentleman i spoke with said he built and raced pro stock motors, so i took him on his word.
Re: Wiped Cams [Re: mopar dave] #2852496
11/28/20 11:22 AM
11/28/20 11:22 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Uuuhh....... seems like a “Captain Obvious” statement to me.
A properly machined cam made from a casting with the correct heat treat won’t go bad on its own??
Huh.
Re: Wiped Cams [Re: fast68plymouth] #2852515
11/28/20 12:16 PM
11/28/20 12:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well, I had a post all typed out about the 509 cam..... and poof..... it disappeared before I could enter it.
I’m not typing it out again and the new shorter version is.......
It’s not a 509 cam after all...... looks like it’s a 484 cam.
Lobe lift varies about .006”, even when measured in areas of the lobe with zero wear.
The wear pattern doesn’t go all the way across of the nose of the lobe.
I checked several lobes for taper...... they’re right about .0015”.
Re: Wiped Cams [Re: mopar dave] #2852518
11/28/20 12:23 PM
11/28/20 12:23 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
this statement should read " IF THE LIFTER DOESNT SPIN , FAILURE IS COMING QUICKLY" !! it is a good idea to make sure their is rotation in the lifters ......
Re: Wiped Cams [Re: ek3] #2852576
11/28/20 02:44 PM
11/28/20 02:44 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I went roller instead of hyd flat tappet because of all the flat cam lobe drama.ive talked to a ton of people about cams in the last 2-3 months,and the consensus is insufficient taper on the lobes. General opinion seems to be they need .003 out of the box?
Re: Wiped Cams [Re: Uberpube] #2852580
11/28/20 02:50 PM
11/28/20 02:50 PM
E
ek3 Offline
ek3  Offline
E
taper is on both the cam and lifter faces... tool steel lifters can fix a lot of this.....
Re: Wiped Cams [Re: fast68plymouth] #2852662
11/28/20 06:16 PM
11/28/20 06:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yep, who makes/grinds that cam? Do you know if nitriding would have saved that cam lobe?
Re: Wiped Cams [Re: mopar dave] #2852857
11/29/20 12:04 PM
11/29/20 12:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
If you’re referring to the cam in my pic...... it doesn’t look good in the pic, but that lobe is perfectly fine.
As are all the others.
The brighter area on the left is untouched by the lifter.
The lift on both sides of the lobe is within .001”.
The color of the cam and lack of parkerizing should be a dead giveaway as to where it came from.
Re: Wiped Cams [Re: fast68plymouth] #2852866
11/29/20 12:19 PM
11/29/20 12:19 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, well thats interesting. I would say it's a purple shaft, but i never ran one. I know nothing about them.
Re: Wiped Cams [Re: ek3] #2852896
11/29/20 12:54 PM
11/29/20 12:54 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Lifter is supposed to be flat, taper on the cam. That’s why the lifter turns. I think another problem is the cam load center has to be on the outside of lifter (cam to far in or out) to close to the center it’s harder to turn. Look at the cam in the hole, roller dead center, solid-hydraulic offset. imo
Re: Wiped Cams [Re: cudaman1969] #2852901
11/29/20 01:02 PM
11/29/20 01:02 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Lifter should be Convex, & cam ground on a taper
Re: Wiped Cams [Re: CSK] #2852908
11/29/20 01:15 PM
11/29/20 01:15 PM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
Exactly.
Re: Wiped Cams [Re: fast68plymouth] #2852929
11/29/20 02:39 PM
11/29/20 02:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I call bs on that
Re: Wiped Cams [Re: cudaman1969] #2852933
11/29/20 02:49 PM
11/29/20 02:49 PM
So. Burlington, Vt.
So. Burlington, Vt.
I call bs on that
Hilarious.
The fact that the lifter faces aren’t flat is common knowledge.
It isn’t some new revelation.
Here’s a pic from the old DC engine manual from the 80’s:
Re: Wiped Cams [Re: fast68plymouth] #2852935
11/29/20 02:52 PM
11/29/20 02:52 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Sorry, cudaman, but you are wrong, no BS... the name "flat tappet" is a misnomer anyway. There is about a 30 inch radius on the curvature, pretty much impossible to see with the naked eye over a .904" diameter, but it is there.
The usual test is to put two lifter bottoms together and they should rock, since they are both convex. That will also let you see the gap as you rock them. twocents
