Re: Ultrasonic carb cleaning
[Re: MO_PA]
#2852198
11/27/20 02:17 PM
11/27/20 02:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
What is a good solution to use for cleaning carbs? Thanks. I would contact Crest Ultrasonics, they supply Industrial grade solutions for specific alloys, any thing you buy at parts stores will be junk...
[Re: MO_PA]
#2852242
11/27/20 04:02 PM
11/27/20 04:02 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Before you buy expensive cleaners, try tap water with a little Dawn dishwashing detergent added.
[Re: mopars4ever]
#2852270
11/27/20 05:00 PM
11/27/20 05:00 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
When I was working for a company making small ultrasonic cleaners, we used ammonia. You want to have the water at least 130 degrees. Don't leave it in the cleaner very long. Max 5 minutes. Remember the ultrasonic attacks aluminum. In my 30 gallon cleaner it will make holes in aluminum foil in 20 seconds.
Dawn would be my second choice for a small cleaner.
[Re: RealWing]
#2852427
11/28/20 01:57 AM
11/28/20 01:57 AM
Posts: 1,840 South Bend
John Brown
South Bend
Chemicals can break down in ultrasonic cleaners and form toxic gasses. I'd hate to hear of anyone getting a case of the deads from not reading the precaution labels.
[Re: John Brown]
#2853707
12/01/20 09:51 AM
12/01/20 09:51 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I use a mix of “LA’s Totally Awesome” from the dollar tree in mine. Works excellent.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2853736
12/01/20 11:05 AM
12/01/20 11:05 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I've tried a dozen suggestions from various forums trying to save money on ultrasonic soap but none of them have worked for me. I get great results buying the real stuff from someone that sells ultrasonics. Remember, different metals might require different soap. On old Holley carbs the throttle plate is aluminum but the rest is zinc.
2011 Drag Pak Challenger
[Re: John_Kunkel]
#2854935
12/03/20 08:36 PM
12/03/20 08:36 PM
Posts: 595 Nashville, Tennessee
Tempest
Before you buy expensive cleaners, try tap water with a little Dawn dishwashing detergent added. This and HOT water. Use it for gun parts all the time as well.
