What is the best chain, Solid Roller application
#2851818
11/26/20 01:47 PM
11/26/20 01:47 PM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
Who makes a good roller chain that can handle a solid roller with a little spring load (600 lbs open) ? Has anyone used Rollmaster or IWIS chains? I been told they were the best but it appears that Mopar applications, especially undersizes are impossible to find.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: What is the best chain, Solid Roller application
[Re: turbobitt]
#2851965
11/26/20 07:19 PM
11/26/20 07:19 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Best thing I have ever found for helping timing chains not stretch is to soak them in Redline 85-90 wt synthetic gear oil for several days before installing them. I also tap on them while they soak in a ziplock bag on their side to get the air bubbles to float off and allow more oil into the rollers. This has virtually eliminated chain stretch on a half dozen motors I've had.
I stumbled across it when I ran out of chainsaw bar & chain oil one spring. My chainsaw chains last 5 or 6 times as long with it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: turbobitt]
#2852052
11/27/20 05:09 AM
11/27/20 05:09 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I would highly suggest a good American Company, Pro Gear. All I ever used, other than occasional Rollmaster set if I was out of ProGear stuff.
RIP Monte Smith
[Re: jbc426]
#2852070
11/27/20 08:01 AM
11/27/20 08:01 AM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I stumbled across it when I ran out of chainsaw bar & chain oil one spring. My chainsaw chains last 5 or 6 times as long with it. I had never soaked chains in the past until Monte Smith mentioned it on here one time Since they don't get any direct oiling they take most of the wear early on if they are not soaked in oil before install. I had never done that and soaking made total sense. I don't mind paying for Quality parts but I'm cheap(mopar duh lol) in the sense I don't like to pay for rebranding of quality parts. When it comes to timing chains I have found that the ones Summit sells are the exact units that Comp Cams sells for about $40-50 cheaper. Just an FYI
68 Barracuda Formula S 340
[Re: CompWedgeEngines]
#2852083
11/27/20 09:12 AM
11/27/20 09:12 AM
turbobitt
Southington Ct.
I would highly suggest a good American Company, Pro Gear. All I ever used, other than occasional Rollmaster set if I was out of ProGear stuff. Is there any indication on the Progear chain links as to the chain manufacture ? I would rather stay away from Rollon or DID chains. AG.
[Re: turbobitt]
#2852142
11/27/20 12:28 PM
11/27/20 12:28 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Pro gear uses a Rolon chain. Made in india.
Because of not so great reviews on that chain I have a pro-gear set on the shelf I replaced with Rollmaster that uses German Iwis.
[Re: jbc426]
#2852148
11/27/20 12:39 PM
11/27/20 12:39 PM
Thumperdart
State of confusion
Even better is to soak em in oil in a frying pan and heat the oil to a few hundred degrees then the oil is impregnated into the metal.....Pettis Performance trick....
[Re: Thumperdart]
#2852168
11/27/20 01:18 PM
11/27/20 01:18 PM
INTMD8
Lake Villa Il
Oil impregnates non porous steel?
[Re: INTMD8]
#2852194
11/27/20 02:01 PM
11/27/20 02:01 PM
Thumperdart
State of confusion
Look at it under a magnifying glass and get back with us......
[Re: INTMD8]
#2852233
11/27/20 03:46 PM
11/27/20 03:46 PM
Posts: 4,103 Yes
sixpakdodge
Yes
Because of not so great reviews on that chain I have a pro-gear set on the shelf I replaced with Rollmaster that uses German Iwis. Rolon makes two different grades of chain. What is referred to as the "gold" chain is just as good as the Iwis. The standard Rolon is the one with durability issues. For what it's worth, I used Rollmasters on the last three engines I built, and keep two new ones on the shelf, but the ones on the shelf are quite dusty these days.
[Re: sixpakdodge]
#2852276
11/27/20 05:11 PM
11/27/20 05:11 PM
CompWedgeEngines
Syracuse,NY
I’ve never had an issue with a Pro Gear chain. Yes, there are two versions. Whats worth noting, is many “ chain failures” are not the chain at all. It’s a gear issue. Wearing gears, and especially, eccentricity. The chain is often blamed for another actual problem. The actual gear manufactures study this stuff quite extensively.
RIP Monte Smith
#2852414
11/28/20 12:27 AM
11/28/20 12:27 AM
INTMD8
Lake Villa Il
As I understand it, the Iwis chain manufactured for Rollmaster is unique as it's stretched at the component length rather than a bulk length of chain, per request of Rollmaster.
I do believe the Rolon gold chain is better than their standard chain, but from the research I've done, does not seem to be on the same level as the Iwis made for Rollmaster.
Just my opinion.
If someone wants to test a new Pro-gear/Rolon gold setup on a solid roller Hemi as I am putting together, let me know and I'll send you the one I have.
[Re: moparx]
#2852546
11/28/20 01:19 PM
11/28/20 01:19 PM
Thumperdart
State of confusion
That may be true but I'm just repeating what one of the best engine builders on earth showed me years ago and I could be wrong on the temps cos it's been many years since I worked there.....
