Re: Need 4-speed A833 bolt pattern
[Re: 440Jim]
#2852005
11/26/20 10:12 PM
11/26/20 10:12 PM
Posts: 10,560 Rittman Ohio
fourgearsavoy
Rittman Ohio
Jim I'll be down in the shop first thing in the morning and I will post the measurements then. I have one on the bench I just rebuilt. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2852077
11/27/20 08:41 AM
11/27/20 08:41 AM
Posts: 16,934 NC
440Jim
NC
The old Mopar Performance Chassis manual might have the bolt pattern in it. I know I've seen the pattern before. I have that book, and it does show the bolt holes, but not the dimensions. Just the engine to bellhousing dimensions.
[Re: Jeremiah]
#2852079
11/27/20 08:46 AM
11/27/20 08:46 AM
Posts: 16,934 NC
440Jim
NC
My Google searches didn't find that one. That looks useful, 5.285" top spacing (side-side), and 7.115" bottom spacing. Surprised the old engineers didn't make them fractions of an inch, like almost everything else back then. i.e. 5.281 = 5-9/32 and 7.125 = 7-1/8 I have seen them document just 2 decimal points, since manufacturing tolerances are used; i.e. 5.28" and 7.13"
[Re: 440Jim]
#2852080
11/27/20 08:58 AM
11/27/20 08:58 AM
fourgearsavoy
Rittman Ohio
Well that certainly is better than my tape measurements I have. The diagram posted above is pretty much what I measured. Gus
[Re: 440Jim]
#2852128
11/27/20 11:59 AM
11/27/20 11:59 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
My Google searches didn't find that one. That looks useful, 5.285" top spacing (side-side), and 7.115" bottom spacing. Surprised the old engineers didn't make them fractions of an inch, like almost everything else back then. i.e. 5.281 = 5-9/32 and 7.125 = 7-1/8 I have seen them document just 2 decimal points, since manufacturing tolerances are used; i.e. 5.28" and 7.13" There is an engineering diagram floating around my shop. It was supposedly supplied by someone from Chrysler to Lakewood back in the day. Origin long forgotten on my end. If it pops up while we are cleaning shop to move I will post it up.
[Re: AndyF]
#2852151
11/27/20 12:46 PM
11/27/20 12:46 PM
Posts: 16,934 NC
440Jim
NC
Which part are you trying to build? I am just making provisions on an engine run stand for use of a bellhousing and flywheel. Engine supported by the transmission side of the bellhousing. The primary method of support on this stand is an engine midplate and racing flywheel (GM style) used on chassis cars/dragsters. The depth of the bellhousing is the most important for this, to make sure the supports have a place to sit. There will be an area >13" wide for the supports; I am not drilling the holes for the supports until an engine with the bellhousing is brought in.
[Re: 440Jim]
#2852186
11/27/20 01:46 PM
11/27/20 01:46 PM
Jeremiah
Rogue River, OR
I would use a heim joint and some threaded rod with an "L" or 90 deg bracket on the end with a provision (ie turn buckle) to take up the slack. There are so many variances on this stuff that you need very finite adjustment. Think dyno cart. It might be best to find a case and bearing retainer (or complete transmission) and just transfer punch the pattern over. That is what I ended up doing for both my Lenco and Gf5r projects.
