What is the best chain, Solid Roller application #2851818
11/26/20 01:47 PM
11/26/20 01:47 PM
Southington Ct.
turbobitt Offline OP
Southington Ct.
Who makes a good roller chain that can handle a solid roller with a little spring load (600 lbs open) ? Has anyone used Rollmaster or IWIS chains? I been told they were the best but it appears that Mopar applications, especially undersizes are impossible to find.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: What is the best chain, Solid Roller application [Re: turbobitt] #2851871
11/26/20 03:11 PM
11/26/20 03:11 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
Hughes engines may not list it but they should have them....
Re: What is the best chain, Solid Roller application [Re: turbobitt] #2851965
11/26/20 07:19 PM
11/26/20 07:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Best thing I have ever found for helping timing chains not stretch is to soak them in Redline 85-90 wt synthetic gear oil for several days before installing them. I also tap on them while they soak in a ziplock bag on their side to get the air bubbles to float off and allow more oil into the rollers. This has virtually eliminated chain stretch on a half dozen motors I've had.
I stumbled across it when I ran out of chainsaw bar & chain oil one spring. My chainsaw chains last 5 or 6 times as long with it.
Re: What is the best chain, Solid Roller application [Re: turbobitt] #2852044
11/27/20 12:43 AM
11/27/20 12:43 AM
i have used the 9 way adjustable Cloyes high dollar race sets on motors up to 860 Lbs. open pressure shifting at 7000+ RPM for hundreds of runs at the strip and 3,000 + hard street miles before having them break shruggy
Cloyes had issues on those upper gears for a while, they wouldn't fit under a stock cover, but I think they got that correct now scope
Re: What is the best chain, Solid Roller application [Re: turbobitt] #2852052
11/27/20 05:09 AM
11/27/20 05:09 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I would highly suggest a good American Company, Pro Gear. All I ever used, other than occasional Rollmaster set if I was out of ProGear stuff.
RIP Monte Smith
Re: What is the best chain, Solid Roller application [Re: jbc426] #2852070
11/27/20 08:01 AM
11/27/20 08:01 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had never soaked chains in the past until Monte Smith mentioned it on here one time Since they don't get any direct oiling they take most of the wear early on if they are not soaked in oil before install. I had never done that and soaking made total sense.
I don't mind paying for Quality parts but I'm cheap(mopar duh lol) in the sense I don't like to pay for rebranding of quality parts. When it comes to timing chains I have found that the ones Summit sells are the exact units that Comp Cams sells for about $40-50 cheaper. Just an FYI
68 Barracuda Formula S 340
Re: What is the best chain, Solid Roller application [Re: CompWedgeEngines] #2852083
11/27/20 09:12 AM
11/27/20 09:12 AM
Southington Ct.
Southington Ct.
Is there any indication on the Progear chain links as to the chain manufacture ? I would rather stay away from Rollon or DID chains.
AG.
Re: What is the best chain, Solid Roller application [Re: turbobitt] #2852101
11/27/20 10:53 AM
11/27/20 10:53 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've used Rollmaster in a few engines, very good stuff.
One of them is a solid roller SB that sees 8,000 RPM.
Re: What is the best chain, Solid Roller application [Re: turbobitt] #2852142
11/27/20 12:28 PM
11/27/20 12:28 PM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
Pro gear uses a Rolon chain. Made in india.
Because of not so great reviews on that chain I have a pro-gear set on the shelf I replaced with Rollmaster that uses German Iwis.
Re: What is the best chain, Solid Roller application [Re: jbc426] #2852148
11/27/20 12:39 PM
11/27/20 12:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Even better is to soak em in oil in a frying pan and heat the oil to a few hundred degrees then the oil is impregnated into the metal.....Pettis Performance trick....
Re: What is the best chain, Solid Roller application [Re: Thumperdart] #2852168
11/27/20 01:18 PM
11/27/20 01:18 PM
Lake Villa Il
Lake Villa Il
Oil impregnates non porous steel?
Re: What is the best chain, Solid Roller application [Re: INTMD8] #2852174
11/27/20 01:32 PM
11/27/20 01:32 PM
moparx Offline
moparx  Offline
i would think the heat just allows the oil to soak between the rollers, links, and pins easier due to expansion between the parts.
beer
Re: What is the best chain, Solid Roller application [Re: INTMD8] #2852194
11/27/20 02:01 PM
11/27/20 02:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Look at it under a magnifying glass and get back with us......
Re: What is the best chain, Solid Roller application [Re: INTMD8] #2852233
11/27/20 03:46 PM
11/27/20 03:46 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Rolon makes two different grades of chain. What is referred to as the "gold" chain is just as good as the Iwis. The standard Rolon is the one with durability issues.
For what it's worth, I used Rollmasters on the last three engines I built, and keep two new ones on the shelf, but the ones on the shelf are quite dusty these days.
Re: What is the best chain, Solid Roller application [Re: sixpakdodge] #2852276
11/27/20 05:11 PM
11/27/20 05:11 PM
Syracuse,NY
Syracuse,NY
I’ve never had an issue with a Pro Gear chain. Yes, there are two versions.
Whats worth noting, is many “ chain failures” are not the chain at all. It’s a gear issue. Wearing gears, and especially, eccentricity. The chain is often blamed for another actual problem. The actual gear manufactures study this stuff quite extensively.
RIP Monte Smith
Re: What is the best chain, Solid Roller application [Re: CompWedgeEngines] #2852414
11/28/20 12:27 AM
11/28/20 12:27 AM
Lake Villa Il
Lake Villa Il
As I understand it, the Iwis chain manufactured for Rollmaster is unique as it's stretched at the component length rather than a bulk length of chain, per request of Rollmaster.
I do believe the Rolon gold chain is better than their standard chain, but from the research I've done, does not seem to be on the same level as the Iwis made for Rollmaster.
Just my opinion.
If someone wants to test a new Pro-gear/Rolon gold setup on a solid roller Hemi as I am putting together, let me know and I'll send you the one I have.
Re: What is the best chain, Solid Roller application [Re: Thumperdart] #2852542
11/28/20 01:16 PM
11/28/20 01:16 PM
moparx Offline
moparx  Offline
i was always under the impression heat [450-500 degrees ?] plus a pressure vessel of some sorts was needed to impregnate parts. shruggy
beer
Re: What is the best chain, Solid Roller application [Re: moparx] #2852546
11/28/20 01:19 PM
11/28/20 01:19 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That may be true but I'm just repeating what one of the best engine builders on earth showed me years ago and I could be wrong on the temps cos it's been many years since I worked there.....
Re: What is the best chain, Solid Roller application [Re: Thumperdart] #2852555
11/28/20 01:43 PM
11/28/20 01:43 PM
moparx Offline
moparx  Offline
i've been wrong MORE times than i've been right ! laugh2
beer
Re: What is the best chain, Solid Roller application [Re: moparx] #2852559
11/28/20 01:57 PM
11/28/20 01:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Me too no doubt.....
