1968 & 1969 B Body Hurst Shifter #2851216
11/25/20 01:20 AM
11/25/20 01:20 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Is this shifter still not reproduced? And does anyone know the height and layback dimensions?
Re: 1968 & 1969 B Body Hurst Shifter [Re: GTX MATT] #2851226
11/25/20 02:09 AM
11/25/20 02:09 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bench seat or console? Should assume that if you're also asking about '68 Road Runner (only) then you're asking about a bench seat. But '68 GTX had buckets and console...........and GTX MATT is kind of a give away wink smile
Re: 1968 & 1969 B Body Hurst Shifter [Re: A12] #2851229
11/25/20 03:40 AM
11/25/20 03:40 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Sorry, the bench seat shifter
Re: 1968 & 1969 B Body Hurst Shifter [Re: GTX MATT] #2851365
11/25/20 01:11 PM
11/25/20 01:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm not aware of any reproduction of the "plug-in" OEM Hurst shifter.
I have, though, drilled a stock lever for the bolt-in style Comp+ shifter and it works fine.
For the OEM version, as far as I know they're rebuildable, if you're OK with tying the car up for that.
Re: 1968 & 1969 B Body Hurst Shifter [Re: A12] #2851387
11/25/20 01:38 PM
11/25/20 01:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
GTX had buckets , but the console was optional
Re: 1968 & 1969 B Body Hurst Shifter [Re: GTX MATT] #2855515
12/05/20 12:32 AM
12/05/20 12:32 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Check with Brewers Performance in Ohio. Wayne may have a used original or know where you can find one.
