518 trans in a 70's D100 #2850923
11/24/20 02:31 PM
11/24/20 02:31 PM
Northport, al.
tvt59 Offline OP
tvt59  Offline OP
Northport, al.
Who has done this , how do you like it? How did you work the throttle pressure and did you put your lockup and overdrive on a switch?
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: 518 trans in a 70's D100 [Re: tvt59] #2850963
11/24/20 03:42 PM
11/24/20 03:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I did it on a 74 D100 short bed behind a 408 stroker small block . I used the PATC site for ideas on lock up and OD controls but sourced the parts from a local trans supplier. I used Mopar kick down linkage. I hear Bouchillons kick down cable kit works well. Made the 3:91 rearend livable for a daily driver.
Re: 518 trans in a 70's D100 [Re: stumpy] #2851162
11/24/20 10:45 PM
11/24/20 10:45 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
I did it in my 77 440 truck. Like it a lot. I used the PATC vacuum and pressure switch set up also. Mine is a lock up version and I installed a cut off switch on the dash. Went from 10 mpg on the interstate to a best of 14.4 mpg running 75-80 mph on the interstate. Only negative I will say is pulling large hills or getting up to speed on a hill it kicks in and out and in and out. I have just got to the point where when I know it is going to do it a lot I turn overdrive off till I get past that point. But cruising with the overdrive and lock up is nice truck sounds like it is barely up off idle. My tach doesn't work so I can't give you a real RPM difference number. Any questions ask away it has been a while since I installed it probably about 10 years and will do it all over again on the 78 I'm working on. up
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
