727 Dolly #2848886
11/20/20 12:53 AM
11/20/20 12:53 AM
AndyF Offline OP
AndyF  Offline OP
I used to keep my spare transmission on a little furniture dolly but got tired of that so decided to build something a bit studier. I fabricated a few different versions but finally settled on this one since it was fairly simple and easy to make. I used the same 5 inch casters that I use on my engine dollies even though it is a bit over kill for a 727. But it rolls nice and it has clearance for a deep pan.
Re: 727 Dolly [Re: AndyF] #2848889
11/20/20 01:07 AM
11/20/20 01:07 AM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
NICE!
Re: 727 Dolly [Re: mopacltd] #2848937
11/20/20 09:28 AM
11/20/20 09:28 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
like it
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 727 Dolly [Re: bigdad] #2848976
11/20/20 10:45 AM
11/20/20 10:45 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Nice! Sure beats dragging one across the floor!
Re: 727 Dolly [Re: fbs63] #2849004
11/20/20 11:49 AM
11/20/20 11:49 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'm still using the furniture dollies , but I like this a lot.
If I had more than one I was currently tripping over , I would do this.
Re: 727 Dolly [Re: AndyF] #2849043
11/20/20 12:55 PM
11/20/20 12:55 PM
AndyF Offline OP
AndyF  Offline OP
I used the same idea on an engine/transmission assembly. The single caster in back works just fine on concrete but I don't think I'd try dragging it over the lawn.
Re: 727 Dolly [Re: AndyF] #2849079
11/20/20 01:59 PM
11/20/20 01:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I wonder about making the trans end the swiveling caster, with the engine sides non-swiveling.
Suppose it depends on how you move it.
I suppose on the 727, having it vertical would challenge the seals with ATF inside ?
I've stored 'em vertically (when dry) on those small furniture dollies.
Re: 727 Dolly [Re: topside] #2849120
11/20/20 03:01 PM
11/20/20 03:01 PM
AndyF Offline OP
AndyF  Offline OP
I only buy swivel casters. Never tried it with solid casters. The few things I've moved around with solid casters on one end are more awkward to slide into tight spots since you can't move them sideways.
Re: 727 Dolly [Re: AndyF] #2849237
11/20/20 08:46 PM
11/20/20 08:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Like how you could still tip up and store it on the face plus protects the mounting face.
Re: 727 Dolly [Re: AndyF] #2849607
11/21/20 03:08 PM
11/21/20 03:08 PM
moparx Online content
moparx  Online Content
ask me why i had trouble positioning a huge tool cabinet i fabbed out of 1/8" steel that i put the swivel casters on the wrong end. laugh2 swivel casters are your friend !
as always Andy, VERY nice work ! up
beer
