Holley Sniper EFI, my experience #2848072
11/18/20 11:50 AM
11/18/20 11:50 AM
Martinsville, IN
cdwmotorsports Online content OP
cdwmotorsports  Online Content OP
Martinsville, IN
So as I go along on this journey from carb to FI I'm going to post progress and notes, issues etc. I have a new QFT carb and by the time I learned how to tune all of the circuits in it I figured I might as well learn to tune FI. Also I've walked outside on plenty of sub 50 degree days in Indiana wanting to drive the car only to never get it to fire up because it was too cold. I walked out the other day on a low 40's day and it fired right off at the hit of the key. I have heard and seen a lot of negative talk about the Sniper kits and to be honest I let some of it get in my head and it delayed me finishing the install. So I've decided to work through the install in stages. I have right now installed it in the most basic the install can get which is bolting it on and hooking up 4 wires.
I had it installed and all but one wire hooked up, a buddy of mine I hadn't seen in 12 years or so comes by the house with his son and his son had never seen or heard it run. While we were sitting there bs'ing I decided to go ahead and wire the last wire in and fire it up. What a fire up it was, once everything was cycled and the software setup for engine parameters we were off and running. Literally hit the fuel pump, ignition and water pump switches and turned the key. It lit off faster than any carb its ever had on it. We let it warm up a bit and get into learn mode and started driving, first my buddy and I and then his kid and I. We drove it probably an hour that day without a hint of an issue with the system. It got a 3.23 sure-grip between the carb/FI swap and the car really liked that. Now that the other hoghead is done its time to swap it in and really have some fun.
My next goal is to wire the fuel pump in to the holley system and let it run the pump rather than me having to turn it on and off. Once Im happy with that I'm going to let the system control the ignition timing and then the fans and water pump.
When I'm confident the ignition control is right I'm calling a tuner in Houston and letting him do the remote tuning setup on it.
Impressions thus far, don't be scared of it. I was intimidated at first but if you follow the suggestions of guys that know the systems they work just fine. I wouldn't throw all the wiring on at once as IMO that's just asking for problems.
I have determined the Powermaster 55 amp alt is nowhere near enough amps to run the electrical stuff in my car. That upgrade is being figured out currently, but if anyone knows of a different bigger amp alternator that will hang off Andy's motor-plate low mount alt kit I'm all ears.
I ordered and installed the following...
Holley kit Stealth Super Sniper
Fuel pump A1000
Regulator Bypass regulator
I also have the following previously installed
MSD Pro Billet Distributor
MSD 6AL box (Analog)
eBay-cdwmotorsports
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848073
11/18/20 11:59 AM
11/18/20 11:59 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I have one on my Big Hemi....Love it. Especially for cooler weather. Startups made easy. Bought mine thru FastManEFI Rich....Alternator is a big 140amp CVF chevy 1-wire...They are awesome.
Re: Holley Sniper EFI, my experience [Re: Dragula] #2848088
11/18/20 12:30 PM
11/18/20 12:30 PM
Tampa FL
BillR1212 Offline
BillR1212  Offline
Tampa FL
I run the sniper on my procharged Cuda. At this moment it's working great with no issues. With that said, it's not for everyone. Especially if the car is a mess of wires and bad grounds. Early on I wired it up and it started up and drove great. 20 miles into my test drive the ECU went bad. Everyone blamed my wiring even though I followed the instructions. Holley sent a new sniper, I had it wired up again by somebody more proficient than me. Worked for a little while, then ECU issue again. This time I bought a new sniper since I was in a pinch. Put it on the car and plugged it into the existing harnesses and my car fired right up and ran fine. This leads me to believe that there is some quality issues with it, and I keep my spare on hand when on long drives.
Re: Holley Sniper EFI, my experience [Re: Dragula] #2848089
11/18/20 12:32 PM
11/18/20 12:32 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I did the same thing. I love the sniper for its simplicity. it is amazing for a street car.
Have you looked into the toyota alternator ? I have put that on 3 mopars now. I love it.
Re: Holley Sniper EFI, my experience [Re: Dragula] #2848102
11/18/20 12:43 PM
11/18/20 12:43 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
No doubt about it regarding the Sniper. I installed it on my 69 Charger with the EFI ready tank from Holley as well as the Holley Hyperspark timing control. I had the same issue as you here in the winter time in Texas. My 440/512 with a QF 1000 carb, and it did not like to start. The Sniper and timing control were the best thing I ever did to my car. Now, it doesn't matter the temp, it fires right up! And the timing control is awesome! The car runs phenomenal. We have a small musclecar shop here in North Texas, and I have installed 6 more Snipers, a 63 Chevy 409 4-speed Impala, 73 Ford Gran Torino 351C. a 1970 455 Olds (Q-Jet), a 1950 Dodge rat rod, 68 Vette, and 2 others I just can't remember right now. I have also installed the Fitechs and Edelbrock systems, and how have a 68 Charger that just came in with a Summit brand EFI setup. But the Holley is superior imho.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Holley Sniper EFI, my experience [Re: 8urvette] #2848138
11/18/20 01:33 PM
11/18/20 01:33 PM
Martinsville, IN
Martinsville, IN
I haven't yet. Does it look like this? If so maybe it will bolt in place and still use Andy's mount. Any certain part number you have would be beneficial.
This one is plenty big enough amp wise but there is no way its gonna work with Andy's motor-plate mount and the Doty pulley
8142
eBay-cdwmotorsports
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848143
11/18/20 01:38 PM
11/18/20 01:38 PM
Tampa FL
BillR1212 Offline
BillR1212  Offline
Tampa FL
I'd like to comment that Holley's tech support has always been great. If you don't want long wait times I'd recommend joining the sniper facebook group. Grab a few names of the techs that reply. Once you have that you can direct message them on facebook and ask for a call back, or work with them via chat. In my case, I'll get them on the phone and have them call my shop if they're working on my car so they're not wasting time on hold.
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848145
11/18/20 01:40 PM
11/18/20 01:40 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
if memory serves its a early 90's toyota truck alternator. but make sure to buy the pigtail too.
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848197
11/18/20 03:11 PM
11/18/20 03:11 PM
Martinsville, IN
Martinsville, IN
It appears the 75 amp will work size wise for mounting do you guys think another 5 amps at idle and 20 amps driving is enough?
8173
My 8172 is 30/55 this one is 35/75
The Powermaster tech guy said I need 90 amps at idle. I'm going to attempt to modify Andy's mount to work with this mechman alternator
Mechman 170
eBay-cdwmotorsports
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848247
11/18/20 04:54 PM
11/18/20 04:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Holley Sniper EFI, my experience [Re: John_Kunkel] #2848251
11/18/20 04:57 PM
11/18/20 04:57 PM
Martinsville, IN
Martinsville, IN
I don't have stock brackets
eBay-cdwmotorsports
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848280
11/18/20 06:18 PM
11/18/20 06:18 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know what size that alternator is for Andy's bracket. Look up the dimensions for a GM CS130 alternator. They are 105 amp I believe. I run one and with a 5" crank pulley it charges great! I run two fuel pumps, electric water pump, two electric fans, a third fan on my fuel cooler, EFI, lights wipers, headlights, it can run them all and maintain 14.2 or so even at idle. At the track my voltage might move .1 during a pass max. It is one of the best changes I have made to the car.
I let my EFI run everything it can, water pump, fans, fuel pumps, whatever I can let it run I do. The only button I have that isn't run through the computer is my line lock. I went from a bank of switches to nothing but a key, line lock button, and a starter button and I love it that way.
68 Barracuda Formula S 340
Re: Holley Sniper EFI, my experience [Re: cdwmotorsports] #2848287
11/18/20 06:30 PM
11/18/20 06:30 PM
What ever you one you buy make sure it will make more amps than you need by at least 20 % at full load so it can recharge the battery after starting twocents
Re: Holley Sniper EFI, my experience [Re: Bad340fish] #2848316
11/18/20 07:46 PM
11/18/20 07:46 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
That's what I am running on my Dart also. 14+ volts all the time (although my idle is around 1200 so the real low end amps aren't as important).
You can get CS130's in a variety of current ratings too, some quite a bit higher than 105 amps.
For example: https://alternatorparts.com/cs130-cs130d-series-alternators.html
Re: Holley Sniper EFI, my experience [Re: DrCharles] #2848349
11/18/20 09:29 PM
11/18/20 09:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just how big an alternator do you need to run an aftermarket EFI? 90 amps seems serious overkill.
Re: Holley Sniper EFI, my experience [Re: 6PakBee] #2848350
11/18/20 09:37 PM
11/18/20 09:37 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
It's not just for the EFI - look at the previous poster's list. Electric fans pull a lot (my Contour fans draw 40 amps on high). Fuel pumps. Headlights and accessories. Etc. Etc.
All the little things that pull an amp here and two amps there. Adds up. twocents
Re: Holley Sniper EFI, my experience [Re: 6PakBee] #2848422
11/18/20 11:57 PM
11/18/20 11:57 PM
AndyF Offline
AndyF  Offline
You don't need a big alternator to run EFI but you do need a good alternator. EFI is susceptible to electrical noise so the alternator needs to be a late model design, preferably an OEM alternator. I use factory Denso alternators on my EFI cars. I use the 60 amp Denso unit on both of my cars.
Re: Holley Sniper EFI, my experience [Re: DrCharles] #2849100
11/20/20 02:31 PM
11/20/20 02:31 PM
Martinsville, IN
Martinsville, IN
Agreed. At idle. I'm making about 12.3 volts per the Holley "dash" sometimes as low as 11.9. The 55 amp Powermaster isn't cutting it.
eBay-cdwmotorsports
Re: Holley Sniper EFI, my experience [Re: AndyF] #2849102
11/20/20 02:32 PM
11/20/20 02:32 PM
Martinsville, IN
Martinsville, IN
So what is the original application for the Denso alternator you use? WIll it fit your brackets you sell for the motor-plate?
eBay-cdwmotorsports
Re: Holley Sniper EFI, my experience [Re: 6PakBee] #2849104
11/20/20 02:36 PM
11/20/20 02:36 PM
Martinsville, IN
Martinsville, IN
It's not for the EFI alone it's for
Holley kit Stealth Super Sniper, Fuel pump A1000, Regulator Bypass regulator, MSD Pro Billet Distributor, MSD 6AL box, headlights, electric water pump, Contour fans set up, stereo (not currently a need but I want the option of it) and charging the battery
eBay-cdwmotorsports
