Page 5 of 7 1 2 3 4 5 6 7
Re: Why aren't there more forced induction cars? [Re: dizuster] #2847481
11/17/20 11:24 AM
11/17/20 11:24 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Originally Posted by dizuster
For some reason, people don't seem to ever compare apples to apples in this situation. "I only want to build a 600hp big block, because there are no good blocks available to build a 1000hp turbo motor?"
There is a REALLY nice 500-800hp sweet spot for cost effective turbo builds. You can take mostly factory parts and with a little fab work and knowledge, build a very nice 10.0 combo (Which the masses trend towards to stay away from the roll cage, cert, NHRA license, etc...)
That being said...
People are scared to try and fabricate
People are intimidated on how to tune (Fuel vs. Timing vs. Boost)
You WILL need electronics to make a good bracket car (Trans brake, boost controller, etc...)
Mine has now been together for over 8 years and been in the 9's since August of 2014. I would say it's probably never made under 550~600hp in it's entire existance, and probably up close to 900hp when set on kill occasionally. Most the time it lives a nice happy 750hp life as I usually run it right around 9.90 or so.
Same stock 360 block, same stock 360 crank, eddy heads, .540 lift hydraulic roller, 3.55 gear.
Your car is wicked impressive....I would put those new aluminum "steely" wheels on it and a turbo G3 Hemi in it, and see how far you can go.....Love that car. I was shocked when it went well into the 9's....That is a perfect drag week car.
Re: Why aren't there more forced induction cars? [Re: dizuster] #2847482
11/17/20 11:26 AM
11/17/20 11:26 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I don't understand why people think you have to do something special to BB to make it turbo friendly.
There is a wonderful resource o the internet, Richard Holdner, he has a great very informative youtube channel where he boosts EVERYTHING.
It all about ring gap. He has proven the gen 3 semis only need ring gap to live under some boost. He took 440 motorhome engine added ring gap and boost. All dyno proven stuff.
Yes, if you want an all out 30 Psi turbo car you need to build the internals, but 7 to 10 psi OEM stock stuff works in most situations- with proper ring gap.
Re: Why aren't there more forced induction cars? [Re: 8urvette] #2847501
11/17/20 12:06 PM
11/17/20 12:06 PM
Because with good heads and a stroker kit and a turbo, it goes kaboom real easy above 750hp...The block is a big limiter hp wise. Which is why most will just build a 700hp NA stroker.
Re: Why aren't there more forced induction cars? [Re: Dragula] #2847509
11/17/20 12:16 PM
11/17/20 12:16 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I have no first hand experience with this for a BB. However I do have substantial experience with imports. Everybody always said these particular motors come apart at 300 Hp. I have proved that wrong by a long shot. Lost of boost and lower RPMS the import engines live very well. A HP number is just that a number.
A 440 making 800 HP n/a will have to spin much higher ( be a tightly wound motor) than a 440 under 15 psi. A 440 under boost will make so much more tq and HP at a lower rpm than a NA I believe it will last a long time. I will see soon enough.
Re: Why aren't there more forced induction cars? [Re: Dragula] #2847583
11/17/20 01:26 PM
11/17/20 01:26 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I keep hearing those numbers but keep ignoring them...LOL. runaway
Light weight rotating assembly, keeping the revs under 6500 and out of detonation are probably keeping hope alive.
'63 Dodge 330
11.19 @ 121 mph
Re: Why aren't there more forced induction cars? [Re: Dragula] #2847597
11/17/20 01:37 PM
11/17/20 01:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It is a good question for sure .And as pointed out by many a boosted application can be done for far less money and will put far less stress on a block than an equally powered NA deal. I built this thing back in the 1990's. I could drive it anywhere, provided there were enough gas stations smile I used to drive it to the track and run 9's and drive it home, and back then there was not alot of that going on. It was using off the shelf parts on a stock block and iron Stage V(wedge stage V not hemi). I never hurt it and have no idea where it is or if it was run much at all after me. I had a great time with the car and was always a blast to drive. Maybe its time for me to build something with a power adder. I have dabbled with nitrous stuff also back in the 90/2000's. I left it to focus on NA stuff, and I can PROMISE you trying to make big power NA is more expensive than the power adder way. I could have had a helluva torbo.blower deal for the money I have dumped into going "fast" NA
Re: Why aren't there more forced induction cars? [Re: 8urvette] #2847669
11/17/20 03:34 PM
11/17/20 03:34 PM
My last 440/512 stroker was built back in 2010 and went as fast as 9.70 at 138.5mph on pump gas NA, won the Championship in 2013 with it.....I put hundreds of passes on it and its now in a street car with less cam and iron heads running 10.70's,,,,,,,So tell me again how a drag motor can't live long...Made 700hp most of its life with no power adder....I want to run 1000-1300hp and a stock block is asking for a lot of trouble at that level. If that engine had an after market block, I would have changed pistons, and added boost and knocked a full second off our ET and gone 8.70's but there in lies the issue, I called everyone I could think of for a block, and nobody had one...... I don't car about a 600hp turbo 4cyl or an 800hp turbo G3 when I have a +800hp NA street car...We are looking to go a bit faster. Cars in the "street class" these days show up with a 632 and two kits on it.....my junk don't compete with that.
And I am no fan of imports so don't park behind me, I use them as wheel chocks...lol
Re: Why aren't there more forced induction cars? [Re: Dragula] #2847706
11/17/20 04:31 PM
11/17/20 04:31 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The only thing stopping you from going faster is the false limits you put on an oe block. Aftermarket blocks do not insure an engine will not fail.... it just makes an engine more tolerable to tuning mistakes.
Not saying everyone is capable of keeping an engine alive, but as long as there are those that can, shows it can be done. There definitely is some risk/ reward in trying.
Re: Why aren't there more forced induction cars? [Re: TRENDZ] #2847726
11/17/20 04:57 PM
11/17/20 04:57 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
AH...back to stock block big blocks.....i went 9.teens at 3500+ lbs. 446 wih two NOS plates stacked on it. I just expected to "drive over the crank" every pass, but it never happened...LOL
Stock Block/main caps , Stock 3.75 stroke crank, Alum rods....It lasted what seemed forever ! ! Never a problem ran that for a few seasons. ANd that was early 90's
....BAD A$$ STREET CAR.....
Re: Why aren't there more forced induction cars? [Re: plycuda] #2847785
11/17/20 07:14 PM
11/17/20 07:14 PM
Tampa FL
BillR1212 Offline
BillR1212  Offline
Tampa FL
Originally Posted by plycuda
my deal I have been running big blocks for 40 years. you can find parts easy and cheap. my motor in my satelite i got the eagle crank and rods for 700 and they were new. had a couple engines that I got years ago for nothing just to tow the cars out.throw on a set of sr heads and flat tops.bought nitrous selonoids and plates off people changing over to turbos cheap and my all steel satelite in street trim full exhaust stock interior, radio playing went a 5.96 at 117 with a 200 shot. im going to a daily driver race sunday see if I can go quicker. I would like to try a pro charger but they don.t make anything for old mopars, plenty for new stuff.
The supercharger store makes brackets for 340 and 440 engines.
Re: Why aren't there more forced induction cars? [Re: TRENDZ] #2847795
11/17/20 07:26 PM
11/17/20 07:26 PM
You can tell that to the guy that just did my headers....He just knocked all the bores out of a .03 over 440 with a 6/71 right above the fill, seems 20psi is a tad too much.....the BBM has limits, and he has found most of them over the years. So go ahead, make 1000hp with a stock block, we have one running down at the shop, and one not running down at the shop....They do not like a lot of boost....Sure people build them, yes they go fast, and yup, they let go.....We just built a 512 B1 stock block 440.....We will see how many passes that makes, its 10:1 with 10psi with a roots 6/71....They do sound good while they last, I wish the video I took would have captured correctly, all I can say is wow, but I will wait till I have a block.
Re: Why aren't there more forced induction cars? [Re: Dragula] #2847804
11/17/20 07:49 PM
11/17/20 07:49 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I'm curious: how much spark lead do these RB blower motors use?
I've heard numbers as low as 15 degrees for LS.
Yellow Bullet probably has some traffic on this.
Boffin Emeritus
Re: Why aren't there more forced induction cars? [Re: polyspheric] #2847807
11/17/20 07:54 PM
11/17/20 07:54 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
id imagine every motor will behave differently. I had a 383 mopar on a dyno N/A and it loved timing. it kept making power at 41* I stopped adding timing and even backed it off a few, lost a few HP but it is street car. Back down at 20* the car was a total dog. Funny, I really thought 41* was just stupid high, but it loved it.
What do LS motors run N/A timing?
Re: Why aren't there more forced induction cars? [Re: polyspheric] #2847814
11/17/20 08:07 PM
11/17/20 08:07 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Not sure on boost but the conservative recommendation for nitrous is pull 2° for every 50 hp shot. Personally I pull 6° for 30° total on a 200 shot. The LS engines use a LOT less timing due to the more efficient combustion chambers.
'63 Dodge 330
11.19 @ 121 mph
Re: Why aren't there more forced induction cars? [Re: GY3] #2847834
11/17/20 09:08 PM
11/17/20 09:08 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
R3 block and thick azz W8 heads.... I’ve got a great foundation.
Re: Why aren't there more forced induction cars? [Re: polyspheric] #2847900
11/17/20 11:30 PM
11/17/20 11:30 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
For higher horsepower turbo LS (say 1200-1600hp) I usually end up at most high teens. Maybe 17deg at 30psi on race fuel or E85. A few deg less at peak torque. 10 to 10.5-1 static CR
Factory forced induction LSA/LS9 at 20psi or so can run mid 20's timing on E85.
My first forced induction endeavor was a roots blown big block chevy when I was 19 in 1997. Because of books I read at the time the compression was -WAY- too low at 7.8-1 so it would take 30 deg from a locked out distributor with 12psi boost on 93.
Re: Why aren't there more forced induction cars? [Re: INTMD8] #2847917
11/18/20 12:02 AM
11/18/20 12:02 AM
oregon
greendart408 Offline
oregon
R3, W8 you say...... have about 20 half azz 1/8 passes and been a nightmare so far. In the midst of about a 10k efi/intercooler switch as we speak so I can hopefully try to enjoy it again.
It’s not for the faint of heart, wallet or for a person who can’t fab.
Re: Why aren't there more forced induction cars? [Re: dvw] #2847967
11/18/20 06:18 AM
11/18/20 06:18 AM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
Originally Posted by dvw
There's a difference between being cash limited and cheap. That being said 800hp tyrbo car is cheaper to build than an 800 N/A. The skill set is different as there is some tubeing and mounting fabrication. It's really basic hot roding. I would be my sons (Diszuter) 360 turbo motor in my chassis would run with-in .10-.20 of what my 15-1 572 -1Indy motor runs. It's been together a while with less maintenance than mine.
Doug
So True! I'm in a lower tax bracket then most. I don't think mopar guys are cheaper than brand X guys. They out number us a lot. Most brand X are worse than mopar guys because they are used to getting everything so cheap.
Re: Why aren't there more forced induction cars? [Re: Smoparmike] #2847975
11/18/20 07:35 AM
11/18/20 07:35 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
https://youtu.be/o9YaXV0ojLk
They are a blast when you get them lined out.
Its just a basic bracket motor on 18 pounds of boost.
4s peddling and 162MPH in the 1/8.
And I got PLENTY left
Re: Why aren't there more forced induction cars? [Re: FastmOp] #2847986
11/18/20 08:25 AM
11/18/20 08:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think WHEN I eventually go turbo I will need someone to password protect the boost controller for my own good.
68 Barracuda Formula S 340
