Molnar crankshaft power limit #2847581
11/17/20 01:26 PM
11/17/20 01:26 PM
MN
JERICOGTX Offline OP
MN
What is the HP limit of a Molnar crankshaft. Or should I say one that you would be comfortable with?
69 GTX 68 Road Runner
Re: Molnar crankshaft power limit [Re: JERICOGTX] #2847591
11/17/20 01:35 PM
11/17/20 01:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'd call Molnar and ask Tom directly.
He struck me as a pretty straight shooter.
The piece with my 408 kit checked all the boxes and I would be confident throwing much more than I am going to at it.
For off shore and inexpensive , I really like it.
But if I was going full on , pants down and look out , I would probably go a different direction.
Re: Molnar crankshaft power limit [Re: tubtar] #2847608
11/17/20 01:55 PM
11/17/20 01:55 PM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
900
Re: Molnar crankshaft power limit [Re: cesar perez] #2847612
11/17/20 02:00 PM
11/17/20 02:00 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Originally Posted by cesar perez
900
I would suspect that a big block crank could go into 4 digits , but not too far.
The usual suspects come into play too...............reciprocating weight , tune , etc.
Re: Molnar crankshaft power limit [Re: cesar perez] #2847613
11/17/20 02:03 PM
11/17/20 02:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Tom will tell you HP means squat. He will ask you bob weight, rpm limit, and if it's a power adder motor. Mine runs a Molnar 4.500/2.200 crank and their 7.100 rods. Bob weight is 2222. Motor has a 7400 chip. Over 300 passes. Car has been 9.0#150@3350#.
Doug
Re: Molnar crankshaft power limit [Re: dvw] #2847622
11/17/20 02:15 PM
11/17/20 02:15 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I trust my builder (Tony Bischoff @ BES). I'm at 1060 hp with a 574 CI.
Re: Molnar crankshaft power limit [Re: dvw] #2847626
11/17/20 02:23 PM
11/17/20 02:23 PM
gregsdart Offline
gregsdart  Offline
Doug
Glad to read this. I am pondering a whole new rotating assembly and was about to call molnar. Same deal; 4.5 stroke 7.10 rods. Would use a 7400 chip also.
Re: Molnar crankshaft power limit [Re: gregsdart] #2847686
11/17/20 04:04 PM
11/17/20 04:04 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Doug
My chip will be 8000. I run Oliver rods. I was trying to buy a Callies crank and that didn't go too good. Tony was not concerned with the Molnar crank.
Re: Molnar crankshaft power limit [Re: JERICOGTX] #2847808
11/17/20 07:56 PM
11/17/20 07:56 PM
New York
polyspheric Offline
polyspheric  Offline
New York
In theory, the crank's stiffness (bending resistance) goes down with:
1.greater length (SB is stiffer than BB, other dims omitted, increased bore pitch)
2. longer stroke
3. reduced main or rod journal diameter (BBC rod journal)
When in doubt, larger radius at the journal edges helps.
I wrote some comments on journal overlap on my site: http://victorylibrary.com/mopar/journal.htm
Boffin Emeritus
Re: Molnar crankshaft power limit [Re: polyspheric] #2847813
11/17/20 08:04 PM
11/17/20 08:04 PM
MN
MN
My plan is to run a 4.375 stroke, with Oliver rods. Won’t be spinning it much over 7000.
Re: Molnar crankshaft power limit [Re: JERICOGTX] #2847828
11/17/20 08:50 PM
11/17/20 08:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Tom Molnar is quite happy to chat about t I am sure. He worked at Oliver before starting up on his own. Email him via his website or try contacting him directly on Facebook. Really knowlegable as you expect.
Alan Jones
Re: Molnar crankshaft power limit [Re: JERICOGTX] #2847830
11/17/20 09:00 PM
11/17/20 09:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I run Molnar crank (4”) and rods (6”) in my small block.... only 246 passes on it though. Rod size considerably smaller than the Eagles we had in the W5 mill.
Re: Molnar crankshaft power limit [Re: J_BODY] #2848026
11/18/20 10:27 AM
11/18/20 10:27 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I have one for my 572 that is in the works. It should be an 850ish package shifting around 6800-7000.
Bought on the recommendation of others. I think I will be happy.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Molnar crankshaft power limit [Re: dvw] #2848045
11/18/20 11:04 AM
11/18/20 11:04 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Doug
100% my experience when I asked about an HP limit on rods. Tom is the best!
Re: Molnar crankshaft power limit [Re: dvw] #2848091
11/18/20 12:33 PM
11/18/20 12:33 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Doug
If I was doing this combo I would use a Molnar crank and rods up to 900hp and 7500-7800rpm. Tom has put a LOT of R&D and analysis into his products. If you are wanting to make more power or turn more RPM I would use aluminum rods. They are WAY easier on everything else. R&R, BME or GRP are good choices. They will last 300 passes as long as they are heat soaked before the first pass and you don't motor down on them. All the OLD myths about aluminum rods are just that. MYTHS.
Re: Molnar crankshaft power limit [Re: fbs63] #2848123
11/18/20 01:15 PM
11/18/20 01:15 PM
New York
polyspheric Offline
polyspheric  Offline
New York
300 passes was Bill Jenkins' limit as well
Boffin Emeritus
Re: Molnar crankshaft power limit [Re: polyspheric] #2848300
11/18/20 06:53 PM
11/18/20 06:53 PM
gregsdart Offline
gregsdart  Offline
I am surprised the rod manufacturers don't trust the general public with some accurate method of determining a life span of thier aluminum rods.
Some formula based on piston weight, piston speed and any other factor that has a mesurable affect on rod life would be great. There is a great deal of difference in actual life span between a pro stocker and a lawn mower!
Take for instance a motor i built back in 1986. 440 stock crank offset ground to 4 inch with a 2.100 sbc bearing. BME 396 forging rods made up with 7.15 c to c length. This motor never saw more than 6500 rpm and had a very light piston. I bet the life of those rods was(or is!) Thousands of runs due to low rpm, moderate stroke and light piston. I ran into the guy i sold that shortblock to about ten years later and he said it was still running great!
Re: Molnar crankshaft power limit [Re: gregsdart] #2848339
11/18/20 09:00 PM
11/18/20 09:00 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Exactly
Boffin Emeritus
