Page 1 of 3 1 2 3
Help me pick a EFI for a 540 #2847456
11/17/20 10:59 AM
11/17/20 10:59 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I am about to start my project again
Its a 68 barracuda with a 18 spline 4 speed. 540 CI stroker. edelbrock victor heads, lightly ported, big solid roller cam, large headers etc...
I want to go to a single turbo down the road. The first step will be to go to fuel injection.
I have done a holley sniper kit on a 65 coronet, a FItech on a SBC and then several imports fuel injection.
I liked the sniper and the FItech, but for my car I am thinking about going with the edelbrock pro flow 4. https://www.jegs.com/i/Edelbrock/350/35920/10002/-1
i know it is only rated to 550 HP, but with bigger injectors it will support almost whatever is thrown at it. I do not know anyone who has used this setup. I have never seen it in person.
has anyone used this setup? likes? dislikes? other options I did not mention?
i will be purchasing this in the next month or so.
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847522
11/17/20 12:28 PM
11/17/20 12:28 PM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
I wouldn't want that system for a turbocharged 540, personally.
I think you would be happier with a Holley HP or Dominator for something like that.
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847525
11/17/20 12:30 PM
11/17/20 12:30 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
a blow through setup????? Why?
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847536
11/17/20 12:39 PM
11/17/20 12:39 PM
Lake Villa Il
Lake Villa Il
A blow through setup is in reference to a carburetor correct, or are you referring to something else?
I don't know what you would need for inputs/outputs. The HP system is nice if you don't need many.
https://www.holley.com/products/fuel_systems/fuel_injection/hp_efi/hp_ecu/parts/554-113
https://www.holley.com/products/fue...ominator_efi/dominator_ecu/parts/554-114
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847545
11/17/20 12:45 PM
11/17/20 12:45 PM
AndyF Offline
AndyF  Offline
You don't want the Edelbrock system for anything serious. The Edelbrock system is a black box setup where the user doesn't have much access or control. If you want a system that can work NA and down the road with a turbo then you need to start with a Holley setup. The Sniper could get you there but it might be a stretch. You most likely want a system with port injection and either a HP or a Dominator ECU.
Re: Help me pick a EFI for a 540 [Re: AndyF] #2847564
11/17/20 01:09 PM
11/17/20 01:09 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
So you are saying the edelbrock setup is just too plain, there are not enough available ways to tune it. There is a limited "set" of parameters and that is all you get. As where the HP or Dominator have limitless adjustable parameters.
I really like the way the edelborck Xt system looks though. Does edelbrock make a better tuning software? Something else I can purchase?
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847567
11/17/20 01:11 PM
11/17/20 01:11 PM
Lake Villa Il
Lake Villa Il
Yes like Andy said, edelbrock is limited control. It has self learning functions but not really enough access to tune something like you're building correctly, in my opinion.
No reason you couldn't run the Pro-flo XT manifold and control it with a Holley system.
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847569
11/17/20 01:14 PM
11/17/20 01:14 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
No reason you couldn't run the Pro-flo XT manifold and control it with a Holley syste[spoiler][/spoiler]m.
i like that option. what about controlling the spark? would I use holleys distributor then?
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847571
11/17/20 01:16 PM
11/17/20 01:16 PM
Lake Villa Il
Lake Villa Il
I opted for Andy's crank trigger and cam sensor for mine but you could run the Holley dual sync distributor if you like.
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847572
11/17/20 01:18 PM
11/17/20 01:18 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
you are running coil packs then?
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847576
11/17/20 01:21 PM
11/17/20 01:21 PM
Lake Villa Il
Lake Villa Il
Well it's not running yet but yes I'm going to use Ford Coyote coils.
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847579
11/17/20 01:24 PM
11/17/20 01:24 PM
Lake Villa Il
Lake Villa Il
Also, Rich Nedbal can get you set up with everything you need.
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847580
11/17/20 01:26 PM
11/17/20 01:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Edelbrock uses a EFI TECHNOLOGIES ecu. As delivered , it is semi locked. Limiting some parameters that actually need attention are not open to the user.
You can, at a cost, fully unlock the ecu. It is not user friendly.
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847582
11/17/20 01:26 PM
11/17/20 01:26 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have been looking at something for a smaller N/A motor , and since I like E-85 , it seems to come down to this one.
FAST
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847587
11/17/20 01:31 PM
11/17/20 01:31 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The aforementioned Eddy intake can be had without their efi....I have also heard bad things about their support for the efi....Like none. If you want the intake, I think its a great intake if it fits the big runner heads and then call Rich at FastmanEFI
https://www.jegs.com/i/Edelbrock/350/7144/10002/-1
Re: Help me pick a EFI for a 540 [Re: tubtar] #2847590
11/17/20 01:34 PM
11/17/20 01:34 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
FAST
I like E-85 myself, but is the fast boost capable? Then it appears to maybe be a slightly improved version of the sniper
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847594
11/17/20 01:36 PM
11/17/20 01:36 PM
Lake Villa Il
Lake Villa Il
The Holley efi is also E85 compatible. I'll be using a composition sensor with mine.
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847602
11/17/20 01:45 PM
11/17/20 01:45 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
i have been running e 85 in on of my cars for a while now and i tested it for the longest time, it was always good. never had low content. always 85 ish. There is only 1 station around me and year round they are close to 85%. I have stopped testing . Probably good idea to get sensor, just havent needed it yet.
Re: Help me pick a EFI for a 540 [Re: 8urvette] #2847603
11/17/20 01:47 PM
11/17/20 01:47 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
FAST
I think you would start here building a system for a boosted application.
FAST controller
Re: Help me pick a EFI for a 540 [Re: INTMD8] #2847625
11/17/20 02:19 PM
11/17/20 02:19 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
who is that and where do i find him?
Page 1 of 3 1 2 3
