Right way to do Leak Down Test? #2846447
11/15/20 10:09 AM
11/15/20 10:09 AM
Bowler Wisconsin
Smoparmike Offline OP
Bowler Wisconsin
I have a 505 street/strip engine it has less than 50 miles on it and 4 passes. I did a compression check on it and all 8 holes were pretty close (165-170psi). I bought a leak down tester to check it further. What is the best engine warm or cold or doesn't it matter? Thanks Mike
Re: Right way to do Leak Down Test? [Re: Smoparmike] #2846479
11/15/20 11:20 AM
11/15/20 11:20 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Some people might say warm, I do everything cold. Cold is easy to be consistent. When you start a test warm it is cooling off every minute you work on it.
68 Barracuda Formula S 340
Re: Right way to do Leak Down Test? [Re: Bad340fish] #2846502
11/15/20 11:45 AM
11/15/20 11:45 AM
Bowler Wisconsin
Bowler Wisconsin
True
Re: Right way to do Leak Down Test? [Re: Smoparmike] #2846522
11/15/20 12:14 PM
11/15/20 12:14 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
You are not in a hurry so I would do it warm a couple cylinders at a time.
Re: Right way to do Leak Down Test? [Re: Smoparmike] #2846523
11/15/20 12:14 PM
11/15/20 12:14 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I do everything cold as well.
Put the piston at TDC, true TDC. If you get it at true TDC the crank will not turn. But you may need to set up each cylinder 2-3 times to get it there. If its not there it will turn the crank. DO NOT attempt to put a breaker bar on the crank and hold it, you will get hurt. You would be amazed at the amount of force 100 PSI on a 440 piston generates (it is enough to drive through a well adjusted E brake about 1 foot every few minutes)
Also, don't expect 2-3% leak down numbers. I was never a huge believer in leak down tests, and as time goes on the results I've seen have pushed me more away from them. The best results I ever got was 2% "Hero" results on a late model engine that made 125 PSI cranking compression (150-160 would be ideal) and did not run that great.
Re: Right way to do Leak Down Test? [Re: GTX MATT] #2846529
11/15/20 12:25 PM
11/15/20 12:25 PM
Bowler Wisconsin
Bowler Wisconsin
Thanks for the pointer. I'm not expecting any huge differences since compression test was pretty consistent.
Re: Right way to do Leak Down Test? [Re: Bad340fish] #2846625
11/15/20 03:19 PM
11/15/20 03:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If it's in the same heated garage.
Ambient isn't consistent.
Boffin Emeritus
Re: Right way to do Leak Down Test? [Re: Smoparmike] #2846651
11/15/20 04:04 PM
11/15/20 04:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
I do them both ways, dead cold after sitting overnight in the shop and then warmed up to at least 180F. I do it at TDC usually but you can test with the pistons down in the cylinders like piston engine aircraft mechanics due up
They remove all the plugs and use the prop to bring the piston up far enough so both valves are closed and due the test there scope Some will do it at TDC also but not all of them do that shruggy
I use a aircraft gauge now, two gauges and reset the first gauge pressure so it has 80 lbs. pressure with air going into the cylinder being tested at TDC and read the pressure lost with the second gauge going to the cylinders with 80 lbs. on the first gauge up
Re: Right way to do Leak Down Test? [Re: Cab_Burge] #2846698
11/15/20 05:52 PM
11/15/20 05:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
As an aircraft mechanic I've done lots of these, the publication AC 43.13-1b outlines the correct procedure. The test is done on a warm engine and, to start the test, air is introduced into the cylinder while the piston approaches TDC and is finalized with the piston at TDC. The airplane has an advantage because of the prop, you can grab a prop blade and manipulate the piston position instead of just parking it at TDC. This assures that the ring is fully seated against to bottom of the ring land.
Re: Right way to do Leak Down Test? [Re: John_Kunkel] #2846809
11/15/20 10:41 PM
11/15/20 10:41 PM
Bowler Wisconsin
Bowler Wisconsin
Thanks everyone
Re: Right way to do Leak Down Test? [Re: polyspheric] #2846879
11/16/20 08:08 AM
11/16/20 08:08 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Agreed, but the temp you start the test at will likely be the same temp you finish with, unless you are super slow lol.
Re: Right way to do Leak Down Test? [Re: John_Kunkel] #2846880
11/16/20 08:10 AM
11/16/20 08:10 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is interesting, and makes total sense. If you have a balancer that is marked every 90 agrees and you do your leak down test following the firing order you should be good on this aspect as long as you don't pass the mark and back it up.
Re: Right way to do Leak Down Test? [Re: Bad340fish] #2847088
11/16/20 03:34 PM
11/16/20 03:34 PM
I have rock the crank backwards and forwards to see if it make any difference, it can up, but don't move it much more than 2 to 4 degrees from TDC , it will blow the piston down if you do shruggy
Re: Right way to do Leak Down Test? [Re: Cab_Burge] #2847099
11/16/20 03:47 PM
11/16/20 03:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
From my experience, rocking back and forth from TDC a little does improve the test results.
Re: Right way to do Leak Down Test? [Re: John_Kunkel] #2847105
11/16/20 03:54 PM
11/16/20 03:54 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
One thing I've noticed is tapping open a valve when the cylinder is under pressure (soft mallet) can lower the leakdown percentage as the pressure shock squares the pistons/rings in the bore.
Re: Right way to do Leak Down Test? [Re: John_Kunkel] #2847107
11/16/20 03:57 PM
11/16/20 03:57 PM
I've seen 3 to 6% shruggy
The piston and ring design has a lot to do with leak down results.
All the stock aircraft pistons I've seen have tapered rings sides, (not square or parallel like car motors have) like some H.D. diesel motors do, correct John ?
Re: Right way to do Leak Down Test? [Re: Cab_Burge] #2847371
11/17/20 01:45 AM
11/17/20 01:45 AM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
So, which one is a better determinant of whether or not it's time for a refresh?
Re: Right way to do Leak Down Test? [Re: Greenwood] #2847378
11/17/20 04:03 AM
11/17/20 04:03 AM
I look for 15% or worst on my race motors and similar on hot street motors.
That would be with 65 lbs. to the cylinder being tested with 80 lbs. out put pressure on my test gauge pressure wrench
Re: Right way to do Leak Down Test? [Re: Cab_Burge] #2848385
11/18/20 10:48 PM
11/18/20 10:48 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
I just did a comp test on my 360. Nominal 12.5 compression. 180+ on 1, 4, 5, & 7. 190+ on 6, 200 on 2, 210 on 3 & 8. This was dead cold. Just for curiosity's sake, I sprayed some WD40 in #1 and retested. It gained a few psi. Thoughts?
Re: Right way to do Leak Down Test? [Re: Greenwood] #2848452
11/19/20 03:28 AM
11/19/20 03:28 AM
I haven't done a compression tests in more years than I can remember, 20 yrs+ blush
I do remember doing them both cold and hot and adding oil into the weak cylinders to see if that helped the rings seal better, if it didn't increase more than a little bit I was taught it was not the rings leaking, it was usually the valve train causing those issues.
Using a leak down meter you can feel the air leaking around the rings by blocking off one breather and holding your hand over the other one to see if it builds pressure up in the crankcase or not and you can hear it leak by the valves on the carb side and the exhaust sides if it is bad valve sealing up
I do use a brass hammer to pop open the valves when doing a leak down test that I hear leakage from the valves, sometimes it will help and on others not very much shruggy scope
I use them as tools to help me under stand what condition the heads, blocks and rings are in wrench
