Re: Cordoba steering column in a 74 roadrunner [Re: IMGTX] #2857812
12/09/20 09:03 PM
12/09/20 09:03 PM
IMGTX Offline
IMGTX  Offline
Last Set for now. I abbreviated it some do to the 4 file upload limit.
13. Remove the middle housing bolts.jpg14. Lower Housing Removal.jpg15. Spring & Lower Housing.jpg
Re: Cordoba steering column in a 74 roadrunner [Re: IMGTX] #2857909
12/10/20 12:33 AM
12/10/20 12:33 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Wow! Thank you that simplifies the process.I appreciate you taking the time to post that.
Re: Cordoba steering column in a 74 roadrunner [Re: chargers777] #3098183
11/29/22 07:19 PM
11/29/22 07:19 PM
Pittsburgh, PA
roadrunnerh Offline
roadrunnerh  Offline
Pittsburgh, PA
Thank you again!
Harry
1968 Road Runner
1975 Scamp
Re: Cordoba steering column in a 74 roadrunner [Re: IMGTX] #3098276
11/30/22 07:59 AM
11/30/22 07:59 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
This lever is to activate the key in warning buzzer switch which is missed on this column.Nothing to do with any kind of lock system
Re: Cordoba steering column in a 74 roadrunner [Re: chargers777] #3098279
11/30/22 08:04 AM
11/30/22 08:04 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
We put a tilt/cruise column from a Cordoba into my 73 Coronet wagon. Easy swap, but the housing for the shifter, etc did not completely cover the portion of the column that was visible between the steering wheel and the dash. There was probably 2-3 inches of bare metal column visible, which I thought looked awful. Otherwise, very easy, worked great, no issues.
Earning every penny of that moderator paycheck.
DBAP
Re: Cordoba steering column in a 74 roadrunner [Re: NachoRT74] #3098347
11/30/22 12:05 PM
11/30/22 12:05 PM
IMGTX Offline
IMGTX  Offline
True but it prevents you from removing the cylinder if the key is in the lock cylinder. I pointed this out because many cars require the key to be in the lock cylinder to prevent people from removing the cylinder without a key. Especially important on modern columns where you have nothing but the plastic clam shells covering the lock assembly.
If someone is used to newer stuff it can be a frustration I was hoping to avoid.
Awesome picture of that switch. Thank you for posting that. I didn't have one handy and forgot to mention it. up up up
Re: Cordoba steering column in a 74 roadrunner [Re: IMGTX] #3098753
12/01/22 07:27 PM
12/01/22 07:27 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The switch pic is actually taken from rear side so it seems to be reversed to the cylinder pushing lever sense.
And about if the lever blocks the cylinder removal or not, really is not the goal in any case. The cylinder needs to get the lock button ( or lock lever on 70 assembly, not a bolt ) pressed anyway so the column needs to be 50% disassembled and will be easy to note visually the key is not needed for the cylinder removal like it’s needed on glove box cylinder.
But I got what you meant
