Re: help me pick rockers for 440
[Re: Forest]
#2846092
11/14/20 02:10 PM
11/14/20 02:10 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
I'm looking for opinions. We have a 440 in my wife's duster that is drag race use only. It has the ProMaxx heads. I think they are a copy of a Edelbrock RPM? Either way we have ran the motor for 2 seasons with stock rocker arms and push rods. It has a Launati Voodoo hydraulic flat tappet cam with .533 lift. It ended up bending a pushrod and breaking the adjacent rocker arm at the last race this year. So it's time for an upgrade.
Originally I was thinking of the chromoly comp rockers but the max spring diameter is much less than Harland Sharps. I'm open to anyones thoughts or suggestions. I would look into the rockers Mancini is selling. Made by Harland Sharp, lifetime warranty, under 500 bucks. Buddy runs the small block versions of them on his trick flow heads and really likes them. Great bang for the buck https://www.manciniracing.com/ben15alro.html
[Re: Forest]
#2846093
11/14/20 02:13 PM
11/14/20 02:13 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I heve used them ( Comp Magnum Ultra Pros) on 2 engines recently. Mine has stealth heads and uses them with isky 9315 springs, which are 1.550”. No problems at all and no contact at all. Almost 2 years now and about 2500 street miles and a bunch of runs at the track. Work perfectly with no issues. Recently removed and inspected. The other engine has Ttricklow 240s, but their hyd roller springs are 1.54”. So no issues their either.
[Re: Forest]
#2846146
11/14/20 04:03 PM
11/14/20 04:03 PM
Posts: 4,213 New York
polyspheric
New York
The largest diameter pushrods you can fit
Boffin Emeritus
[Re: BSB67]
#2846217
11/14/20 06:02 PM
11/14/20 06:02 PM
Posts: 916 SE Washington
Forest
SE Washington
what spring diameter do you think you need? It currently has 1.45" diameter springs now. My thought was get 2 more seasons on the short block. Then do a stroker kit and possibly a solid roller on the freshen up. I'm not a engine builder, but I don't want to spend $700 on rockers then get in a pickle later on valve springs and wish I would have bought the Harland Sharps...
[Re: polyspheric]
#2846219
11/14/20 06:03 PM
11/14/20 06:03 PM
Forest
SE Washington
The largest diameter pushrods you can fit totally agree, it would be nice if 3/8" would go right in...?
[Re: Chargerfan68]
#2846220
11/14/20 06:10 PM
11/14/20 06:10 PM
Forest
SE Washington
I heve used them ( Comp Magnum Ultra Pros) on 2 engines recently. Mine has stealth heads and uses them with isky 9315 springs, which are 1.550”. No problems at all and no contact at all. Almost 2 years now and about 2500 street miles and a bunch of runs at the track. Work perfectly with no issues. Recently removed and inspected. The other engine has Ttricklow 240s, but their hyd roller springs are 1.54”. So no issues their either. Ok cool, I just read on Summit that 1.45" was the limit, but obviously not! I think they would be a good rocker for the money!
[Re: B3422W5]
#2846223
11/14/20 06:12 PM
11/14/20 06:12 PM
Forest
SE Washington
Originally I was thinking of the chromoly comp rockers but the max spring diameter is much less than Harland Sharps. I'm open to anyones thoughts or suggestions. I would look into the rockers Mancini is selling. Made by Harland Sharp, lifetime warranty, under 500 bucks. Buddy runs the small block versions of them on his trick flow heads and really likes them. Great bang for the buck https://www.manciniracing.com/ben15alro.html Thats interesting...wonder what the difference is? The adjusters? Actual Harland Sharps are nearly double the cost...
[Re: Stanton]
#2846260
11/14/20 08:07 PM
11/14/20 08:07 PM
B3422W5
Portage,michigan
The "difference" is the Harland Sharps that everyone else sells have roller bearings for the shafts whereas the "Mancini" Harland Sharps are bored aluminum like every other aluminum rocker on the market. Hence the price difference. Yep. Still nice for the money,American made, and lifetime warranty
[Re: Stanton]
#2846620
11/15/20 03:16 PM
11/15/20 03:16 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
The "difference" is the Harland Sharps that everyone else sells have roller bearings for the shafts whereas the "Mancini" Harland Sharps are bored aluminum like every other aluminum rocker on the market. Hence the price difference. The early pics of those rocker arms showed bushing installed ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) So they are not bushed that is a disappointment as I was considering them . Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: AndyF]
#2850687
11/23/20 08:32 PM
11/23/20 08:32 PM
Forest
SE Washington
Crane or Comp? We have used the Comp rocker arms on a lot of engines. They work fine with flat tappet or a street roller type cam and generally last a long time. oops yea Comp...
[Re: fourgearsavoy]
#2850868
11/24/20 10:32 AM
11/24/20 10:32 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
So a little " backstory" on the HS non bushed rocker arms. Back when Crane was sold, and the new owners were clearly not interested in making rocker arms again, I thought that there should be a replacement for them, as they were a great little rocker arm, and nothing else really fit the bill in that price range. So, I started working on a HS rocker arm, non bushed, to fill that gap. I worked with them, to use a BBC rocker arm, that was drilled out, as that would be the most cost effective. I have the prototypes still in my shop. The first version, ended up being too short for the valve tip alignment. ( this project probably went on for 4-6 months). So, I was working at changing that distance, and at the same time. getting HS to make their standard rocker arm axle to fit an Edelbrock head properly. I determined it had to be moved .070. That was a done deal and we started selling the " E" version of that rocker. At that time, everyone just " lived with" the length being wrong. I wanted to fix that. Back to the unbushed rocker arm. " Somehow" ( still dont know why), my unbushed rocker design, made it to Mancini .Next thing I know, they had ordered 100 sets or something like that, and I was effectively out of that market. I didnt have the coin to pony up for that kind of investment in one series of rocker. I will post a pic of the original prototypes next trip to the shop.
RIP Monte Smith
