I've started working on the oil system on my Hemi.
Had an MP pan and windage tray.
Bought a Milodon 31580 oil pan and 32000 windage tray to replace it.
Noticed the Milodon windage tray was much closer to the reciprocating assembly which I didn't like. Also, they note in their catalog, #32005 tray was redesigned for better windage scavaging and increased sump protection for big inch inches.
Hmmm, seems odd as the 32000 is full length and 32005 closer resembles in shape of the MP tray.
So, I took the MP tray and added another set of louvers to the drivers side close to the block skirt. Seemed to me logical but my imagination may differ from reality.
Also seemed a flat plate over cross bolted main caps could restrict bay to bay breathing so I made a wooden buck and bumped out the tray over each main cap. Drilled for drainage. Same disclaimer as above.
Next, on to the pans. Wanted to see oil level vs volume. MP pan filled the sump at 4 quarts. 5 took it over.
Milodon pan -nearly- filled the sump at 5. 6 took it over.
Of course everyone says a certain amount of oil is up in the heads/etc in a running engine which brought me to my next thought, cylinder head oil drainback.
Drivers front drains into the timing chain area. The rest drain into the corners of the crankcase right on top of the crank. Strikes me as odd to a point as I would think the passenger side drains would be impeded by oil thrown off the recip.
So, I thought, why not run tubes through the windage tray up to the drain holes. Further thought made me realize that under acceleration more oil would be going to the rear drains......fine. But would it not be better to just drill/tap the heads for an external drain to the pan sump than let the rear drains dump into the back of an oil pan that has a center sump?
Not sure. Maybe it doesn't matter and I'm overthinking things.
