94 V8 Automatic Dakota ECM #284589
04/11/09 11:53 AM
04/11/09 11:53 AM
East Tenn.
Y
yonext2000 Offline OP
Y
East Tenn.
Can someone tell me what factory part number Dodge used for the ECM used in a 94 Dakota V8 with 46 Rh automatic transmission?
dearrington@charter.net
Re: 94 V8 Automatic Dakota ECM [Re: yonext2000] #284590
04/11/09 02:58 PM
04/11/09 02:58 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Wish I still had mine so I could help ya. It was a 318 auto 4x4..Sold it to buy my Ram. Sorry..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: 94 V8 Automatic Dakota ECM [Re: KatFysh] #284591
04/12/09 09:47 AM
04/12/09 09:47 AM
scratchnfotraction Offline
DAKS use there own ecu...a ram one does not work the DAK..IIRC calibrations are diff for the DAK
seem mopar sold a HP ecu for the DAK also for about 200 bones IIRC
I have 2 stock ecu's I will look at later and see if I can find a part # for ya
should be the same on a 93 DAK which mine are both 93 DAKS with 5.2 autos
Re: 94 V8 Automatic Dakota ECM [Re: scratchnfotraction] #284592
04/12/09 04:10 PM
04/12/09 04:10 PM
Somewhere north of Omaha
BorisT Offline
BorisT  Offline
FWIW... the 92-93 are a different part number than the 94-95 piece but they interchange without problems. The 318 PCM will run a 360 with good results and the 360 PCM will run a 318 but performance will suffer.
My reading on www.bionicdodge.com this afternoon says that the Ram/Dak share the same part number. (The Jeep GC used a different PCM)
I believe that I had MP 5249545 in my 94 V8/auto Dak
68 Plymouth Sport Fury Fasttop 290 HP 383/auto/factory AC
