Re: Fire Extinguisher mount
[Re: DusterKid]
#2845653
11/13/20 09:23 AM
11/13/20 09:23 AM
Posts: 876 Arizona
PolyDart
Arizona
Looking to mount a fire extinguisher to my roll bar. Who's mounts do you guys use and like? I use H3Rs Halguard extinguisher with their billet mounts.
[Re: DusterKid]
#2845657
11/13/20 09:29 AM
11/13/20 09:29 AM
Posts: 4,798 On the parachute mount
n20mstr
i dont have a recommendation other than...Make sure its secure!! You dont want it flying around in the event of a crash. Maybe better to look into a fire "system" that has a mounted bottle and plumbed lines. A lot safer than an extinguisher that can come loose and bash you in the event of a roll over or crash
....BAD A$$ STREET CAR.....
[Re: Brewzer67]
#2845672
11/13/20 10:16 AM
11/13/20 10:16 AM
Posts: 1,794 Keymar, MD
DusterKid
Keymar, MD
Here is one I found on Amazon that works really well and looks good. I used a little heat shrink tube on the clamps to spruce it up some. How is the quality of that one? I was looking at it and some of the reviews I've seen said the machining is a little sloppy and it rattles. Not sure if you could really hear it rattle in a race car, but just curious what you thought of the quality of it.
[Re: Brewzer67]
#2859312
12/13/20 11:05 AM
12/13/20 11:05 AM
Posts: 16,768 On the run…
BloFish
On the run…
I’m thinking of mounting one as well. I thought there would have been a lot more responses with pictures.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
