T56 Magnum rear seal leak fix #2845193
11/12/20 04:04 AM
11/12/20 04:04 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
We had a leaky output shaft seal on our T56 Magnum if you guys ever have this issue and need a a seal with a metal flange.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: T56 Magnum rear seal leak fix [Re: RylisPro] #2846015
11/14/20 08:40 AM
11/14/20 08:40 AM
GMP440 Offline
GMP440  Offline
Just noticed something when you did the seal installation close to the end of the video. It might help to put some RTV up , into the rear part of the cavity of the tailshaft where the seal butts up against.
Alot of times there is a little bit of fluid that weeps from this area. It's the same thing that is done when replacing a pinion seal. RTV sealant should be applied to that back area that the pinion seal butts up against.
Many times we always are fighting to solve these leaks even when new seals are put in . This method solves that pesky leak issue.
Re: T56 Magnum rear seal leak fix [Re: GMP440] #2846810
11/15/20 09:45 PM
11/15/20 09:45 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Great point! I don't remember applying silicone to the first seal I installed in 2013 and that one never leaked?
I'll keep an eye out for any more drips as it is pretty easy to service this seal and slap on some RTV thanks!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
