![](http://i14.photobucket.com/albums/a318/goldduster318/hose2.jpg)
I only have this picture as well. I put the calipers on the car in 2003 so I haven't had 'em off at all.
Having worked on brake caliper engineering for my college co-op job (I graduated in December of last year), I've looked at a lot of brake calipers.
I will say the one on the left looks "proper" to me, but the thing you have to remember is that the seal you are talking about is just a dust boot, not the one that seals the fluid in the cylinder...that is a small o-ring type that fits in a groove in the housing. I personally would run both of them provided that the pad can sit flat on the piston on the one on the right.
BTW: those have to be the same calipers, as I have phenolic pistons as well. There are only two piston diameters in slider type and only the larger came with phenolic pistons. So if you don't like it, walk into advance and tell them you need a caliper for an 80 volare with rear mount calipers.
