Best ring pack for pan evac equiped race bb?
#2833933
10/17/20 04:32 PM
10/17/20 04:32 PM
Posts: 10,081 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Curious how thin a ring pack and what tension can be used with a pan evac system? 512 bigblock bracket motor.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Best ring pack for pan evac equiped race bb?
[Re: AndyF]
#2833961
10/17/20 05:27 PM
10/17/20 05:27 PM
gregsdart
Good question. Hook a pressure sending unit up to your data logger and see what the numbers are. Personally I don't trust a pan evac system to do much of anything. If the engine had a vacuum pump then I'd go with a metric ring pack. We've used the Mahle 1/1/3 mm ring packs and they free up some power that is for sure. No running motor at this time, just some pistons with .043/.043/3/16 ring pack. I have considered what to do with the megablock that i split a cylinder in. Fix it, or sell it and a potential buyer doesn't use a vacuum pump. The pistons and rings in seven cylinders only have seven runs on them, and could be built pretty reasonably for what he wants if the .043 rings will work.
[Re: gregsdart]
#2834062
10/17/20 10:07 PM
10/17/20 10:07 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
I bought and used a .043,.043 with a 1/8 inch low tension oil ring for my 518 C.I. 400 block current bracket motor with a vacuum pump I'm not sure what current trick racing sizes are available now as I built that motor two winters ago I like it a lot, runs good , makes a lot of power
[Re: R3 Racing]
#2835688
10/21/20 03:33 PM
10/21/20 03:33 PM
Posts: 4,744 On the parachute mount
n20mstr
Just food for thought here. My son rebuilt a magnum 360. Ball honed , and a standard forged piston. Im pretty sure 1/16 rings. Your standard moly type off the shelf piston/ring. He put an evac system on it, and a vac gauge on the valve cover. Of course it produced little to no vacum. I told him get rid of all the rubber gromets etc. He fabbed some alum pucks with the centers tapped for 3/8 pipe. He welded these onto the valve covers. Got some -10 AN fittings and hose and plumbed it to the headers. Then he put one with a check valve to a breather tank so if there was positive pressure it could vent. This AN setup produces some vacum ! At idle the gauge just comes off "0" . At 55mph on the freeway it has 3" of vac. At the track depending on the air it produces 3-4" of vacum at the stripe. I was impressed. The key is sealing up the connections at the valve covers , as much as you can
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2835693
10/21/20 03:48 PM
10/21/20 03:48 PM
gregsdart
Just food for thought here. My son rebuilt a magnum 360. Ball honed , and a standard forged piston. Im pretty sure 1/16 rings. Your standard moly type off the shelf piston/ring. He put an evac system on it, and a vac gauge on the valve cover. Of course it produced little to no vacum. I told him get rid of all the rubber gromets etc. He fabbed some alum pucks with the centers tapped for 3/8 pipe. He welded these onto the valve covers. Got some -10 AN fittings and hose and plumbed it to the headers. Then he put one with a check valve to a breather tank so if there was positive pressure it could vent. This AN setup produces some vacum ! At idle the gauge just comes off "0" . At 55mph on the freeway it has 3" of vac. At the track depending on the air it produces 3-4" of vacum at the stripe. I was impressed. The key is sealing up the connections at the valve covers , as much as you can Great to know! Thanks.
[Re: 340Cuda]
#2835986
10/22/20 09:33 AM
10/22/20 09:33 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
This last time I went w/ a .043" top, 1/16" 2nd and 3/16" oil ring on my new pistons. New slugs and fresh bores sure seems to have made this old motor run better. Fresh motor check-out/break-in pass earlier this year it ran 9.73 at 139.6 mph w/ only a 1.43 sixty foot. This was all motor w/ a real tight nitrous converter and 3.54 gear.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Dduster]
#2845107
11/11/20 09:48 PM
11/11/20 09:48 PM
Posts: 9,973 MI, usa
dvw
MI, usa
[Re: Dduster]
#2845148
11/11/20 11:35 PM
11/11/20 11:35 PM
Posts: 724 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Same Question??: "Whose Big Block pistons You use for the 1/1/3mm ring package?" i used .9mm .9mm 3mm the pistons are ross Joe
Without Data, you’re just another guy with an opinion.
